Error after Aimeos 19.10 -> 20.4.2 update
bouuman
Post by bouuman » 22 May 2020, 21:11
Start situation:
i try to Update from 19.10.4 to 20.4.2 like you wrote in the manual.
The Extension Upload+Overwrite showed this exception on first try:
Call to undefined method Doctrine\DBAL\Configuration::getSchemaAssetsFilter()
Core: Exception handler (WEB): Uncaught TYPO3 Exception: Call to undefined method Doctrine\DBAL\Configuration::getSchemaAssetsFilter() | Error thrown in file /var/www/vhosts/webXXX.linus.sXXXXXXX.de/httpdocs/vendor/doctrine/dbal/lib/Doctrine/DBAL/Schema/AbstractSchemaManager.php in line 229. Requested URL: https://XXXXXXXXXX.XX/typo3/index.php?r ... ensionFile
then i run the script (circular button), script shows everything "ok" and "done", no errors.
if i Upload + Overwrite again, then the "getSchemaAssetsFilter" error not showing up again and the upload seems to be ok.
Then again circular button.
then i Remove the Aimeos extension template from the root template and add it again, like described.
But mine was looking like this ( i used the preconfigured aimeos typo3 extension when i installed it first time):
Then i get this errors on my page, instead of the shop menu:
if i edit the template and remove the
Bootstrap Package and Aimeos Distribution (aimeos_dist) from the template and leave only Aimmeos Shop configuration (aimeos) then this errros appears in the backend log:
LIVE ERROR Error handler Core: Error handler (FE): PHP Warning: fopen(/var/www/vhosts/weXXXX.liXXX.XXXX.XX/httpdocs/typo3temp/var/lock/flock_b3b32a2d422265cd25c3323ed0157f81): failed to open stream: No such file or directory in /var/www/vhosts/weXXXX.liXXX.XXXX.XX/httpdocs/typo3/sysext/core/Classes/Locking/FileLockStrategy.php line 97
20:08:33 [0]
LIVE ERROR Error handler Core: Exception handler (WEB): Uncaught TYPO3 Exception: #1518472257: Failed to fetch error page "https://XXXXXXXX.XX", reason: Server error: `GET https://XXXXXXXX.XX` resulted in a `500 Internal Server Error` response: <!DOCTYPE html> <head> <meta http-equiv="Content-Type" content="text/html; charset=utf-8"> <meta name="robots" cont (truncated...) | RuntimeException thrown in file /var/www/vhosts/weXXXX.liXXX.XXXX.XX/httpdocs/typo3/sysext/frontend/Classes/Controller/ErrorController.php in line 210. Requested URL: https://XXXXXXXX.XX/index.php?id=13&L=0 ... %5D=detail
20:08:33 [0]
LIVE ERROR Error handler Core: Exception handler (WEB): Uncaught TYPO3 Exception: #1294586099: Lock file could not be opened | TYPO3\CMS\Core\Locking\Exception\LockAcquireException thrown in file /var/www/vhosts/weXXXX.liXXX.XXXX.XX/httpdocs/typo3/sysext/core/Classes/Locking/FileLockStrategy.php in line 99. Requested URL: https://XXXXXXXX.XX/
20:08:33 [0]
LIVE ERROR Error handler Core: Exception handler (WEB): Uncaught TYPO3 Exception: #1294586099: Lock file could not be opened | TYPO3\CMS\Core\Locking\Exception\LockAcquireException thrown in file /var/www/vhosts/weXXXX.liXXX.XXXX.XX/httpdocs/typo3/sysext/core/Classes/Locking/FileLockStrategy.php in line 99. Requested URL: https://XXXXXXXX.XX/index.php?id=13&L=0 ... %5D=detail
20:08:33 [0]
20:08:33 [0]
20:08:33 [0]
20:08:33 [0]
20:08:33 [0]
20:08:33 [0]
20:08:33 [0]
LIVE ERROR Error handler Core: Exception handler (WEB): Uncaught TYPO3 Exception: #1518472257: Failed to fetch error page "https://XXXXXXXX.XX", reason: Server error: `GET https://XXXXXXXX.XX` resulted in a `500 Internal Server Error` response: <!DOCTYPE html> <head> <meta http-equiv="Content-Type" content="text/html; charset=utf-8"> <meta name="robots" cont (truncated...) | RuntimeException thrown in file /var/www/vhosts/weXXXX.liXXX.XXXX.XX/httpdocs/typo3/sysext/frontend/Classes/Controller/ErrorController.php in line 210. Requested URL: https://XXXXXXXX.XX/robots.txt
20:08:33 [0]
20:08:33 [0]
19:57:30 [0]
19:57:56 [0]
20:08:33 [0]
LIVE ERROR Error handler Core: Exception handler (WEB): Uncaught TYPO3 Exception: #1395140007: Cannot create directory /var/www/vhosts/weXXXX.liXXX.XXXX.XX/httpdocs/typo3temp/var/lock/ | TYPO3\CMS\Core\Locking\Exception\LockCreateException thrown in file /var/www/vhosts/weXXXX.liXXX.XXXX.XX/httpdocs/typo3/sysext/core/Classes/Locking/FileLockStrategy.php in line 65. Requested URL: https://XXXXXXXX.XX/
20:08:33 [0]
LIVE ERROR Error handler Core: Exception handler (WEB): Uncaught TYPO3 Exception: #1395140007: Cannot create directory /var/www/vhosts/weXXXX.liXXX.XXXX.XX/httpdocs/typo3temp/var/lock/ | TYPO3\CMS\Core\Locking\Exception\LockCreateException thrown in file /var/www/vhosts/weXXXX.liXXX.XXXX.XX/httpdocs/typo3/sysext/core/Classes/Locking/FileLockStrategy.php in line 65. Requested URL: https://XXXXXXXX.XX/index.php?id=1
20:08:33 [0]
LIVE ERROR Error handler Core: Exception handler (WEB): Uncaught TYPO3 Exception: #1395140007: Cannot create directory /var/www/vhosts/weXXXX.liXXX.XXXX.XX/httpdocs/typo3temp/var/lock/ | TYPO3\CMS\Core\Locking\Exception\LockCreateException thrown in file /var/www/vhosts/weXXXX.liXXX.XXXX.XX/httpdocs/typo3/sysext/core/Classes/Locking/FileLockStrategy.php in line 65. Requested URL: https://XXXXXXXX.XX/index.php?id=1&ai%% ... n%%5D=list
20:08:33 [0]
19:57:37
xxxx_xxxxxxxxxxx
19:57:37
xxxx_xxxxxxxxxxx
if i add the Bootstrap Package and the aimeos_dist back again to the template then this error coming back when i try to load my page:
At the moment i restored my backup and back to 19.10.4.
Can you help me maybe please to update?
Re: Error after Aimeos 19.10 -> 20.4.2 update
Post by aimeos » 23 May 2020, 06:49
At first sight, the errors are not directly related to Aimeos. Can you please delete the ./typo3temp/ directory before/after you upgrade? If the error occors again, can you please post the stack trace of the errors that are written to the ./typo3conf/var/logs/ directory?
bouuman
Post by bouuman » 23 May 2020, 07:53
Hello, thank you for your reply!
i deleted the typo3temp before and after update, but it still the same:
log:
typo3_cde629c9ce.zip
typo3temp/var/log
(7.97 KiB) Downloaded 168 times
rolled back again to 19x.
Post by aimeos » 23 May 2020, 08:35
According to the log you've posted, the problem is:
TYPO3\\CMS\\Core\\Exception\\SiteNotFoundException: No site found in root line of page 1 in /var/www/vhosts/wXXXX.lXXs.sXXXX.XXe/httpdocs/typo3/sysext/core/Classes/Site/SiteFinder.php:138
The Aimeos 20.4 extension uses the TYPO3 site configuration by default. Please check that you've created at least one site configuration in the TYPO3 "Sites" panel in the left navigation bar.
bouuman
Post by bouuman » 23 May 2020, 09:47
Hello again, thank you
ok the Site was there but the Base URL->Language configuration was missing, strange it worked with 19x... dont understand.
After i added the configuration, the page loaded! but didnt loaded like it should be:
(the articles are not shown, i can open the categorys but they are empty.) In typo3 backend the articles still there and are assigned to the categorys.)
before update:
customers menu is empty but they still visible in the database fe_users:
empty customer menu.png (15.55 KiB) Viewed 3522 times
if i create a new customer now, the only difference is the "pid" number. Usually it was always 3... now its 0 for a new customer.
bouuman
Post by bouuman » 23 May 2020, 10:15
db users:
added new user after update:
added new customer.png (25.47 KiB) Viewed 3511 times
Post by aimeos » 23 May 2020, 10:28
bouuman wrote: 23 May 2020, 09:47 ok the Site was there but the Base URL->Language configuration was missing, strange it worked with 19x... dont understand.
TYPO3 is lax about that and works without a configured language. Aimeos 20.4 now enforces a language because it queries the languages available for the TYPO3 site and TYPO3 will throw an error if there are none.
bouuman wrote: 23 May 2020, 09:47 After i added the configuration, the page loaded! but didnt loaded like it should be:
Rebuild the Aimeos index using the scheduler.
bouuman wrote: 23 May 2020, 09:47 customers menu is empty but they still visible in the database fe_users:
Not sure about why the customer menu is empty if you have entries in your fe_users table.
If you want to create customers in the Aimeos backend, you have to configure the page ID so they are able to log in (https://aimeos.org/docs/TYPO3/Install_A ... etup_login):
plugin.tx_aimeos.settings.mshop.customer.manager.typo3.pid-default = 3
module.tx_aimeos.settings.mshop.customer.manager.typo3.pid-default = 3
But the best place is to configure this in the PHP config file in your own extension because then it's available in the frontend, backend and the scheduler without having several configurations. Add it to <yourext>/Resources/Private/Config/mshop.php:
return [
	'customer' => [
		'manager' => [
			'typo3' => [
				'pid-default' => 3
bouuman
Post by bouuman » 23 May 2020, 12:46
ok big thank you so far... i still have only 2 problems (not rolling back at the moment)
1st problem:
missing customers, i can log in the customers because they still in the database but when you try to checkout then this comes up:
2nd problem:
the products appears again after i updated the index via sheduler like you told me thank you,
but Layout and formats of the homepage are gone, it looks strange formated now:
bouuman
Post by bouuman » 23 May 2020, 12:51
typo3temp var log:
typo3_cde629c9ce(1).zip
(9.25 KiB) Downloaded 142 times
Post by aimeos » 23 May 2020, 12:58
bouuman wrote: 23 May 2020, 12:46 missing customers, i can log in the customers because they still in the database but when you try to checkout then this comes up:
Can you please check the siteid column in the fe_users table? It should now contain for your records something like "1." if there's a mshop_locale_site.id record with ID 1 or it can be empty string but NOT NULL.
bouuman wrote: 23 May 2020, 12:46 the products appears again after i updated the index via sheduler like you told me thank you,
The theme has been updated and it differs from the 2019.x version, so you have to adapt it if you have already changed it to your own layout.
