Package types for own extension
cnoelker
Post by cnoelker » 24 May 2020, 11:56
there are several options for package types on the extension generator, located here:
https://aimeos.org/extensions/
In which points do TYPO3 2019.x and TYPO3 2020.x differ? Is this only the ext_emconf.php or are there any breaking changes?
I currently have an individual extension based on the TYPO3 2019.x version. What's the recommended way to update individual extensions? Create a package for type 2020.x and copy the changes in there?
Claudia
Re: Package types for own extension
Post by aimeos » 25 May 2020, 17:25
Between major versions there are always breaking changes, so the best thing is to create a new extension, copy your changed files one by one to the new extension, test and adapt them to the new Aimeos code base. Check the list of breaking changes so you know where to expect problems with old code: https://aimeos.org/docs/Developers#Changelog
