Price display on filtering
Hi
We are using Aimeos for Laravel 2019.04
I hope you can help me out with the following challenge that we have:
Our selection product can have about 70 subproducts (based on a the combinations of length, width and softness)
some of the subproducts have different prices. (price added in the subproduct)
Selection product - no width, length or softness is set - Price is set to €200,-
Subproduct 1 - width = 40 / length = 80 / softness = extra soft - No price set (so uses section product price)
Subproduct 2 - width = 60 / length = 80 / softness = extra soft - Price € 240,-
Subproduct 3 - width = 60 / length = 90 / softness = extra soft - Price € 250,-
subproduct 4 - width = 70 / length = 80 / softness = hard - Price € 280,-
subproduct 5 - width = 70 / length = 90 / softness = extra soft- Price € 280,-
I try to achieve the following without any luck:
When I use the product filter on the frontend and I filter on product width=60 then the price of the selection product € 200,- is still shown. But in reality the price for a product with width=60 has is minimum € 240,-
We where hoping to get the following result:
1) when filtered on width=60 (width=60 has multiple product with different prices, so show lowest price)
then show price "from € 240,-"
2) when fitered on width=70 (width=60 has multiple product but the prices are the same, so show price)
then show "€ 280"
3) when filtered on softness=hard
then show "€ 280"
4) when filtered on softness is extra soft
then show "from € 200"
I hope you can help us to achieve this.
then show "€ 280"
then show "€ 280"
Re: Price display on filtering
That's not possible out of the box because in the list view, only the selection price is shown with "from €200".
To achieve what you want, the list view needs to load the selection articles and their attributes too using https://aimeos.org/docs/Configuration/C ... ts/domains:
Then, you have to implement your own algorithm in the catalog/lists/item-body-* template to filter the articles with the passed attribute ID:
Something like that, I've not tested it but it should give you an impression what you have to do.
'client' => [
'html' => [
'catalog' => [
'lists' => [
'domains' => ['media', 'price', 'text', 'attribute', 'product']
foreach( $product->getRefItems( 'product', null, 'default' ) as $articles ) {
foreach( $articles as $article ) {
if( $article->getListItem( 'attribute', 'variant', $this->param( 'f_attrid', [] ) ) {
$list[] = current( $article->getRefItems( 'price', 'default', 'default' ) );
$price = null;
foreach( array_filter( $list ) as $priceItem ) {
if( $price === null || $priceItem->getValue() < $price ) {
$price = $priceItem->getValue();
Thanks a lot, we will give it a try.
Thank you for the advice, this has helped a lot. We have got this working now.
Now we only have to apply this on the product detail page as well.
