Error after Aimeos 19.10 -> 20.4.2 update
bouuman
Re: Error after Aimeos 19.10 -> 20.4.2 update
Post by bouuman » 02 Jun 2020, 18:00
aimeos wrote: 02 Jun 2020, 14:53 jQuery is missing, you haven't included it in your pages.
Can you describe me short where to add it in the aimeos page structure the easyest way?
In the template setup?
Maybe you have a code exame how it have to look like in the standard configuration?
EDIT:
Sorry i found it, and it works now:
Downloaded the newest file from -> "Example: https://code.jquery.com/jquery-3.5.1.min.js
Rename jquery-3.5.1.min.js to jquery.min.js Upload file to ..../httpdocs/fileadmin/template/js/
Template Setup in Typo3 Backend:
page.includeJSFooterlibs.jquery = fileadmin/template/js/jquery.min.js
.... no idea why this was missing suddenly but everything works again! :)
THANK YOU
