Extending MShop Price
adityabanerjee
Post by adityabanerjee » 06 Jun 2020, 07:13
Hi, I am having a problem in extending this file-:
https://github.com/aimeos/aimeos-core/b ... d.php#L415
To extend this I have done the following -:
1. I have created a file named Ebdaa.php in the dir ebdaa/lib/custom/src/MShop/Price/Item/Ebdaa.php
2.I have added the following code in the above dir path file name Ebdaa.php
<?php
namespace Aimeos\MShop\Price\Item;
class Ebdaa extends Standard
* Add the given price to the current one.
* @param \Aimeos\MShop\Price\Item\Iface $item Price item which should be added
* @param float $quantity Number of times the Price should be added
* @return \Aimeos\MShop\Price\Item\Iface Price item for chaining method calls
public function addItem( \Aimeos\MShop\Price\Item\Iface $item, float $quantity = 1 ) : \Aimeos\MShop\Price\Item\Iface
dd('here');
if( $item->getCurrencyId() != $this->getCurrencyId() )
$msg = 'Price can not be added. Currency ID "%1$s" of price item and currently used currency ID "%2$s" does not match.';
throw new \Aimeos\MShop\Price\Exception( sprintf( $msg, $item->getCurrencyId(), $this->getCurrencyId() ) );
if( $this === $item ) { $item = clone $item; }
$taxValue = $this->getTaxValue(); // use initial value before it gets reset
$this->setQuantity( 1 );
$this->setValue( $this->getValue() + $item->getValue() * $quantity );
$this->setCosts( $this->getCosts() + $item->getCosts() );
$this->setRebate( $this->getRebate() + $item->getRebate() * $quantity );
$this->setTaxValue( $taxValue + $item->getTaxValue() * $quantity );
return $this;
3. In the config/shop.php I have added the following lines -:
'mshop' => [
'locale' => [
'manager' => [
'standard' => [
'sitelevel' => 3
'order' => [
'manager' => [
'base' => [
'name' => 'Ebdaa'
'price' => [
'item' => [
'name' => 'Ebdaa'
This is not getting extended. Please assist. Thank you in advance.
Re: Extending MShop Price
Post by aimeos » 08 Jun 2020, 10:02
You have to overwrite the price manager and the createItemBase() method where you return an instance of your new item class and configure the price manager in your configuration, not the item. Background: The manager is the factory for the items which creates them.
