Price rebate amount
- Advanced
Price rebate amount
I want to know logic behind the rebate amount. I have defined product and all details with price as attached into screenshot. Now, When we ordered that product, it is showing original cost also into basket api it is not returning rebate amount for that product too.
I am bit confused for that. In price section, if rebate amount value is just used for showing percentage value based on original cost then it should return into basket api too. So, I can show over there. Please check attached screenshots.
- price field.png (10.53 KiB) Viewed 1124 times
- basket reponse.png (25.07 KiB) Viewed 1124 times
Re: Price rebate amount
The rebate field is used in the list and detail views to calculate the discout in percent the item is now cheaper than before. In the basket and the order, the rebate field is used to calculate real discounts based on coupon codes or other factors.
