How to prevent loading of aimeos.css
cnoelker
Post by cnoelker » 08 Jun 2020, 08:30
I have one site in TYPO3 which is based on aimeos-dist. This works fine. It uses my CSS and I can completely control the included CSS files.
Then, I created a second site which is (regarding the configuration) basically a copy of the other site. The same constants and setup, the same templates included.
However, when looking at the generated HTML source code, the second site always includes aimeos/Resources/PublicThemes/elegance/aimeos.css which I do not need because I have another theme.
How can I get rid of this? I tried this
plugin.tx_aimeos.theme.css.aimeos >
and also
plugin.tx_aimeos.theme.css.aimeos = EXT:[my-extension]/[path-to-my-css]
plugin.tx_aimeos.theme.baseurl = EXT:[my-extension]/Resources/Public/Themes/[my-theme-directory]
When I search in the TYPO3 object browser for 'elegance', then it's not found. In my extension, nothing with this path is included, either.
Where is this set?
Claudia
tenkraD
Re: How to prevent loading of aimeos.css
Post by tenkraD » 09 Jun 2020, 09:56
https://aimeos.org/docs/TYPO3/Use_custom_themes
page.includeCSS.aimeos >
page.includeCSS.aimeos-common >
page.includeCSS.aimeos-custom >
page.includeCSS.tx_aimeos >
cnoelker
Post by cnoelker » 09 Jun 2020, 10:04
No, this does not work out. It has an effect only on the order of the included Css files, i.e., now the aimeos.css is included at the last position and completely overrides my theme.
tenkraD
Post by tenkraD » 09 Jun 2020, 10:22
Typo3 Site cache deleted?
Because it works for me
cnoelker
Post by cnoelker » 09 Jun 2020, 10:33
Yes, everything deleted.
tenkraD
Post by tenkraD » 09 Jun 2020, 11:25
Can you check your Page object in TS Browser?
Maybe you have it under page.XX.includeCSS.aimeos
page.10.includeCSS.aimeos >
Its working for me, maybe the admin knows your solution.
