Products Out of Stock
I cant find the problem, i have different products that whenever added to the basket display errors like "Product is out of stock", "Remove item from basket", but these products do have stock. Actually at the details page it shows the stock level as high.
I have no idea what is happending. Could you please help me?
Another thing, the stock level at details page displays wierd, where do i set these attributes and how do i fix that.
Thank you very much!
Re: Products Out of Stock
Did you assign a different stock type than "default" in the admin interface for that product?
Can you post a screenshot from the product stock sub-panel for that product?
The translations for the stock message in Spanish isn't good. Can you improve them?
https://www.transifex.com/aimeos/aimeos ... xt%3Astock
You need to register first but it's free of charge.
I guess not, the weird thing is that this happens with just some products.
This is the stock configuration for one of these products This is the stock type config. I´ve changed the code and label to "Stock" just to try to find out what is happenning with translations.
Did you reuse the SKUs of old products for new ones? In that case, the stock entries in the mshop_stock table may not have been removed too.
i have manually removed the mbshop_stock entries from db table. the problem persists.
Another source of the problem: You created a selection product, added a stock level to that selection product but not for its variants. Then, you get that behavior.
The "ProductStock" basket plugin is resonsible for the message and you can deactivate it in the "Plugin" panel of the admin interface for testing.
Thanks, i have disabled to product stock plug in, can i leave it like that for production server??
Im really not interested on stock levels since, most of my products are virtual or on demand..
Yes, you can deactivate the ProductStock plugin if you only have virtual products without negative effects.
If you have mixed physical and virtual products, you need to make sure that all virtual products have an empty stock level entry, which means "unlimited stock".
