Catalog-Filter Pricerange Filtering
Doggiefield
Post by Doggiefield » 13 May 2020, 13:16
We are trying to get a solid filter function for our shop.
But we couldn't find any info on a pricerange filter. Is there a default section in the catalog-filter for a price filter?
If not, what is the best way to implement this?
Re: Catalog-Filter Pricerange Filtering
Post by aimeos » 14 May 2020, 17:10
Not yet but we would like to add this to Aimeos. If you can provide the frontend template, we will care about the backend implementation :-)
Doggiefield
Post by Doggiefield » 16 May 2020, 00:11
Thank you for your suggestion, we will take a look at this and give you an update asap.
SteveCo
Post by SteveCo » 11 Jun 2020, 14:26
Has this happened yet? If not, I can take a crack at it.
Doggiefield
Post by Doggiefield » 11 Jun 2020, 14:53
Due to our current projects it would take us probably a month or so before we can start on this.
So if you have the chance to get this done; that would be great!
SteveCo
Post by SteveCo » 12 Jun 2020, 14:22
Can you clarify the need? Is it just a filter box for the Price Range?
Doggiefield
Post by Doggiefield » 13 Jun 2020, 09:06
We need just a basic priceslider, but when the filterfunction is used it should only use the prices of the filtered result.
I was thinking on a slider like this: https://www.jqueryscript.net/form/Price ... ry-UI.html
This has the option to use a slider or fill in the min & max amount.
Doggiefield
Post by Doggiefield » 12 Jul 2020, 10:58
SteveCo wrote: 11 Jun 2020, 14:26 Has this happened yet? If not, I can take a crack at it.
Hi Steve,
Did you manage to build the frontend implementation?
parmonov98
Post by parmonov98 » 12 Oct 2020, 17:04
I need to create like this.
Have you guys implemented it?
https://i.imgur.com/chEYGBI.png
Post by aimeos » 13 Oct 2020, 09:50
The 2020.10 release already contains a price filter component but a little bit simpler than that.
