How to set a default billing address
cnoelker
Post by cnoelker » 20 Jul 2020, 16:07
as for the billing/payment address, there is always a standard address, so if I access getAddresses() from the standardBasket, then this contains at least one payment address.
Which class needs to be overwritten so that I can set a default delivery address, if the (logged in) user has at least one billing address?
Claudia
Re: How to set a default billing address
Post by aimeos » 22 Jul 2020, 07:41
There's no good reason to duplicate the billing address and add it again as delivery address because the Aimeos code already uses the billing address if no delivery address has been added to the order.
If you want to add the first delivery address of the customer to the order automatically, you can change the template code so the first delivery address is pre-selected instead of "like billing address":
https://github.com/aimeos/ai-client-htm ... hp#L42-L67
cnoelker
Post by cnoelker » 22 Jul 2020, 08:15
Oh, sorry, I accidentally wrote "billing". No, it's all about the delivery address which I want to set as a default.
Thank you for the pointer to the correct file.
