A ware house management system for Aimeos ready
bilginkilic
Post by bilginkilic » 05 Aug 2020, 11:18
Quoting from this link, we would like to ask do you suggest any 3rd party or in house management system that is ready for being an extension of aimeos to provide stock management system. The stock management system is something that controls the goods in a warehouse system, addresses very well has advanced system of barcoding and API service for aimeos to get and set stock number of a product over API.
thank you.
@bilginkilic_ (twitter)
Re: A ware house management system for Aimeos ready
Post by aimeos » 01 Sep 2021, 06:36
There's no concrete connector to an existing solution but it's rather easy to write one if you've found a solution that fits your needs.
