ProductStock plugins
- Advanced
Re: ProductStock plugins
I added dd on the following methods and wanted to check if they are getting invoked or not. It seems that the methods are not getting invoked when I call the following api i.e http://ebdaa-ecommerce.test/syaanh/json ... elatedid=0
This is from the ProductStock -:
Thanks/**
* Receives a notification from a publisher object
* @param \Aimeos\MW\Observer\Publisher\Iface $order Shop basket instance implementing publisher interface
* @param string $action Name of the action to listen for
* @param mixed $value Object or value changed in publisher
* @return mixed Modified value parameter
* @throws \Aimeos\MShop\Plugin\Provider\Exception if checks fail
public function update( \Aimeos\MW\Observer\Publisher\Iface $order, string $action, $value = null )
dd('update debug');
if( ( $value & \Aimeos\MShop\Order\Item\Base\Base::PARTS_PRODUCT ) === 0 ) {
return $value;
\Aimeos\MW\Common\Base::checkClass( \Aimeos\MShop\Order\Item\Base\Iface::class, $order );
if( ( $outOfStock = $this->checkStock( $order ) ) !== [] )
$msg = $this->getContext()->getI18n()->dt( 'mshop', 'Products out of stock' );
throw new \Aimeos\MShop\Plugin\Provider\Exception( $msg, -1, null, array( 'product' => $outOfStock ) );
return $value;
* Checks if all products in the basket have enough stock
* @param \Aimeos\MW\Observer\Publisher\Iface $order Shop basket object
* @return array Associative list of basket product positions as keys and the error codes as values
protected function checkStock( \Aimeos\MShop\Order\Item\Base\Iface $order ) : array
dd('checkStock debug');
$productCodes = $stockTypes = $stockMap = [];
foreach( $order->getProducts() as $orderProduct )
$productCodes[] = $orderProduct->getProductCode();
$stockTypes[] = $orderProduct->getStockType();
foreach( $this->getStockItems( $productCodes, $stockTypes ) as $stockItem ) {
$stockMap[$stockItem->getProductCode()][$stockItem->getType()] = $stockItem;
return $this->checkStockLevels( $order, $stockMap );
* Checks if the products in the basket have enough stock
* Removes products from the basket which are out of stock and decreases the
* quantities of orders products if there's not enough stock.
* @param array $stockMap Multi-dimensional associative list of product ID / stock type as keys and stock level as values
* @return array Associative list of basket positions as keys and error codes as values
protected function checkStockLevels( \Aimeos\MShop\Order\Item\Base\Iface $order, array $stockMap ) : array
dd('checkStockLevels debug');
$outOfStock = [];
$products = $order->getProducts();
foreach( $products as $pos => $orderProduct )
$stocklevel = 0;
$type = $orderProduct->getStockType();
$code = $orderProduct->getProductCode();
if( isset( $stockMap[$code] ) && array_key_exists( $type, $stockMap[$code] ) )
$orderProduct->setTimeFrame( $stockMap[$code][$type]->getTimeFrame() );
if( ( $stocklevel = $stockMap[$code][$type]->getStockLevel() ) === null ) {
continue;
if( $stocklevel >= $orderProduct->getQuantity() )
$stock = $stockMap[$code][$type]->getStockLevel() - $orderProduct->getQuantity();
$stockMap[$code][$type]->setStockLevel( $stock );
continue;
if( $stocklevel > 0 ) { // update quantity to actual stock level
$order->addProduct( $orderProduct->setQuantity( $stocklevel ), $pos );
} else {
$order->deleteProduct( $pos );
$outOfStock[$pos] = 'stock.notenough';
return $outOfStock;
My config/shop.php
'jsonapi' => [
'product' => [
'levels' => 3
'debug' => 1,
'order' => [
'name' => 'EbdaaClientStandard'
'basket' => [
'product' => [
'name' => 'EbdaaBasketProductStandard'
The plugin was not executed because it only listened to "check.after" but not for "addProduct.after". We've fixed that in the master and the latest 2020.07.x-dev branch.
