Couldn't edit frontend user data with 'Aimeos Shop - Account profile' content element
niklas-doerner
Post by niklas-doerner » 16 Aug 2020, 16:18
The frontend login (with felogin) works as well, whether I created a new user manually, with aimeos (end of the checkout process) or with an other frontend user registration extension before.
The Problem is that I can't edit the costumers data with the build in 'Aimeos Shop - Account profile' content element. I have tested it with different extensions like 'femanager' or 'sf_register' and at last manually in the backend.
But when I create the user with aimeos itself at the end of the checkout process (checkbox near terms) then I can edit the user data in frontend with the 'Aimeos Shop - Account profile' content element.
My Versions: TYPO3 10.4.6 / Aimeos 20.7.1 / PHP 7.4.3 / Apache/2.4.41 (Ubuntu) / MySQL 8.0.21 / Bootstrap Package 11.0.2
Re: Couldn't edit frontend user data with 'Aimeos Shop - Account profile' content element
Post by aimeos » 17 Aug 2020, 06:49
Make sure you've set the PID configuration correctly:
https://aimeos.org/docs/TYPO3/Install_A ... etup_login
niklas-doerner
Post by niklas-doerner » 17 Aug 2020, 20:13
I have had done it before. Here:
plugin.tx_aimeos.settings.mshop.customer.manager.typo3.pid-default = 13
I used the PID of the sysfolder, where the Users stored, and here the PID of the actually Page with the Login form:
config.typolinkLinkAccessRestrictedPages = 14
The Login isn't the problem. The users stored correctly and users are able to login and get access of user restricted pages.
Which URL should I use here?
config.typolinkLinkAccessRestrictedPages_addParams = &return_url=###RETURN_URL###
Post by aimeos » 19 Aug 2020, 07:22
niklas-doerner wrote: 17 Aug 2020, 20:13
Maybe it's a problem with the siteid. Guess the value of the "siteid" column is empty for that record in fe_users but is that also the case for the corresponding fe_users_address entry?
niklas-doerner wrote: 17 Aug 2020, 20:13 Which URL should I use here?
None, the marker ###RETURN_URL### is replaced by felogin.
niklas-doerner
Post by niklas-doerner » 21 Aug 2020, 14:14
Hey,
as you see the fe_users_address is empty.
At the other screenshot you see that the pid is taken correctly in plugin.tx_aimeos.settings.mshop.customer.manager.typo3.pid-default = 13
The user with the uid 17 is the user created at the end of the checkout process. Unlike to the user 39, which is created with another extension for user registration.
Screenshot from 2020-08-21 16-02-49.png (49.49 KiB) Viewed 5885 times
Screenshot from 2020-08-21 16-01-05.png (34.24 KiB) Viewed 5885 times
Post by aimeos » 25 Aug 2020, 07:52
Can you please set
plugin.tx_aimeos.settings.madmin.log.manager.standard.loglevel = 7
and open the account profile page in your browser? Then, have a look at the Log panel in the admin backend or into the madmin_log table and search for the SQL that retrieves the data from fe_users. Can you post that statement please?
niklas-doerner
Post by niklas-doerner » 25 Aug 2020, 14:48
Did you mean this output statement?
madmin_log table.zip
(2.09 KiB) Downloaded 534 times
Post by aimeos » 25 Aug 2020, 15:00
Yes. The user with uid 39 should be found and his data displayed in the account profile component because
( ( t3feu."siteid" = '1.' OR t3feu."siteid" = '' ) AND ( t3feu."uid" = 39 AND t3feu."disable" = 0 ) ) AND t3feu."deleted" = 0
matches siteid "1." and an empty siteid which is the case for that user.
niklas-doerner
Post by niklas-doerner » 25 Aug 2020, 15:18
Okay I understand but I don't get what I can do.
Post by aimeos » 25 Aug 2020, 17:13
Found the problem in the update SQL statement:
https://github.com/aimeos/ai-typo3/comm ... df7485fefb
Can you update to 2020.07.x-dev and test if it works for you too?
composer req aimeos/ai-typo3:2020.07.x-dev
