Error when upgrade to 2020.10 latest
- Expert
this command:
gives error:
composer require aimeos/aimeos-laravel:~2019.10 -v
Migrating: 2017_08_11_073824_create_menus_wp_table
Illuminate\Database\QueryException : SQLSTATE[42000]: Syntax error or access violation: 1103 Incorrect table name '' (SQL: create table `` (`id` bigint unsigned not null auto_increment primary key, `name` varchar(191) not null, `created_at` timestamp null, `updated_at` timestamp null) default character set utf8mb4 collate 'utf8mb4_unicode_ci')
at /var/www/schmuck/vendor/laravel/framework/src/Illuminate/Database/Connection.php:664
660| // If an exception occurs when attempting to run a query, we'll format the error
661| // message to include the bindings with SQL, which will make this exception a
662| // lot more helpful to the developer instead of just the database's errors.
663| catch (Exception $e) {
> 664| throw new QueryException(
665| $query, $this->prepareBindings($bindings), $e
666| );
667| }
668|
Exception trace:
1 Doctrine\DBAL\Driver\PDOException::("SQLSTATE[42000]: Syntax error or access violation: 1103 Incorrect table name ''")
/var/www/schmuck/vendor/doctrine/dbal/lib/Doctrine/DBAL/Driver/PDOConnection.php:63
2 PDOException::("SQLSTATE[42000]: Syntax error or access violation: 1103 Incorrect table name ''")
/var/www/schmuck/vendor/doctrine/dbal/lib/Doctrine/DBAL/Driver/PDOConnection.php:61
Re: Error when upgrade to 2020.10 latest
This isn't related to Aimeos at all. Seems like it's one of your own migration files that causes the problem or maybe ask in the Laravel forum why that happens.
- Expert
hm..
This command doesn't update aimeos to version 2019.10.31:
I still have:
composer require aimeos/aimeos-laravel:~2019.10.31
aimeos/ai-admin-jqadm 2019.10.6 Aimeos ai-admin-jqadm extension
aimeos/ai-admin-jsonadm 2019.10.2 Aimeos ai-admin-jsonadm extension
aimeos/ai-client-html 2019.10.10 Aimeos ai-client-html extension
aimeos/ai-client-jsonapi 2019.10.2 Aimeos JSON API extension
aimeos/ai-controller-frontend 2019.10.3 Aimeos ai-controller-frontend extension
aimeos/ai-controller-jobs 2019.10.4 Aimeos ai-controller-jobs extension
aimeos/ai-gettext 2019.10.1 Aimeos Gettext extension
aimeos/ai-laravel 2019.10.2 Laravel adapter for Aimeos web shops and e-commerce solutions
aimeos/ai-payments 2019.10.1 Payment extension for Aimeos web shops and e-commerce solutions
aimeos/ai-swiftmailer 2019.10.1 SwiftMailer adapter for Aimeos web shops and e-commerce solutions
aimeos/aimeos-core 2019.10.7 Full-featured e-commerce components for high performance online shops
aimeos/aimeos-laravel 2019.10.x-dev 1557846 Professional, full-featured and high performance Laravel e-commerce package for online shops and complex B2B projects
- Expert
I have created new project to check the problem:
Then I ran
The components versions are:
And searching getBaseItem method in all project doesn't give result. There is not such method..((
What the problem ? Are you sure this method implemented in 2019.10.31 ?
"name": "name/aimeos",
"authors": [
"name": "mike",
"email": "email@gmail.com"
"prefer-stable": true,
"minimum-stability": "dev",
"require": {
"aimeos/aimeos-laravel": "~2019.10"
"scripts": {
"post-update-cmd": [
"@php artisan vendor:publish --tag=public --force",
"@php artisan migrate",
"\\Aimeos\\Shop\\Composer::join"
composer update
aimeos/ai-admin-jqadm 2019.10.19 Aimeos ai-admin-jqadm extension
aimeos/ai-admin-jsonadm 2019.10.7 Aimeos ai-admin-jsonadm extension
aimeos/ai-client-html 2019.10.20 Aimeos ai-client-html extension
aimeos/ai-client-jsonapi 2019.10.8 Aimeos JSON API extension
aimeos/ai-controller-frontend 2019.10.11 Aimeos ai-controller-frontend extension
aimeos/ai-controller-jobs 2019.10.19 Aimeos ai-controller-jobs extension
aimeos/ai-laravel 2019.10.7 Laravel adapter for Aimeos web shops and e-commerce solutions
aimeos/aimeos-core 2019.10.31 Full-featured e-commerce components for high performance online shops
aimeos/aimeos-laravel 2019.10.6 Professional, full-featured and high performance Laravel e-commerce package for online shops and complex B2B projects
Unfortunately, the getBaseItem() method is only available in 2020.x
