Installation error of TYPO3 9.5 and aimeos 20.7 (composer)
I installed a TYPO3 9.5 (php 7.2) with aimeos 20.7 on a shared hosting (all-inkl) via composer. TYPO3 works fine, but the table creation of aimeos fails, because it cannot find a table called "t3feu.gender" (during demo data installation, as it seems):
I added the required post.installation scripts to the composer.json.
I also updated static-info-tables (which reports that no new tables were created).
The error repeats (ext config is set to "Updates demo data" => "Overwrite").
Am I doing something wrong or is this a bug?
(I think, in "fe_users_address" the field "gender" was renamed to "salutation"? At least I cannot find a table "gender" there...)
Adding default code data for site "default"
Checking "customer/group" codes OK
Processing customer demo data
SQLSTATE[42S22]: Column not found: 1054 Unknown column 't3feu.gender' in 'field list':
SELECT
t3feu."uid" AS "customer.id", t3feu."siteid" AS "customer.siteid",
t3feu."name" AS "customer.label", t3feu."gender",
t3feu."username" AS "customer.code", t3feu."title" AS "customer.title",
t3feu."company" AS "customer.company", t3feu."vatid" AS "customer.vatid",
t3feu."first_name" AS "customer.firstname", t3feu."last_name" AS "customer.lastname",
t3feu."address" AS "customer.address1", t3feu."zip" AS "customer.postal",
t3feu."city" AS "customer.city", t3feu."zone" AS "customer.state",
tsc."cn_iso_2" AS "customer.countryid", t3feu."language" AS "customer.languageid",
t3feu."telephone" AS "customer.telephone", t3feu."email" AS "customer.email",
t3feu."fax" AS "customer.telefax", t3feu."www" AS "customer.website",
t3feu."longitude" AS "customer.longitude", t3feu."latitude" AS "customer.latitude",
t3feu."password" AS "customer.password", t3feu."date_of_birth",
t3feu."usergroup" as "groups", t3feu."pid" AS "typo3.pageid",
t3feu."disable", t3feu."crdate", t3feu."tstamp"
FROM "fe_users" as t3feu
LEFT JOIN "static_countries" AS tsc ON t3feu."static_info_country" = tsc."cn_iso_3"
WHERE ( ( t3feu."siteid" = '1.' OR t3feu."siteid" = '' ) AND t3feu."username" = 'demo@example.com' ) AND t3feu."deleted" = 0
GROUP BY t3feu."uid", t3feu."uid", tsc."cn_iso_2"
ORDER BY t3feu."uid" ASC
LIMIT 100 OFFSET 0
#0 /[path-to-folder]/vendor/aimeos/aimeos-core/lib/mshoplib/src/MShop/Common/Manager/Base.php(553): Aimeos\MW\DB\Statement\DBAL\Simple->execute()
Re: Installation error of TYPO3 9.5 and aimeos 20.7 (composer)
The "gender" column is defined in the ext_tables.sql of the Aimeos extension and it seems it wasn't added automatically.
Can you please deactive and activate the Aimeos extension in den extension manager again?
Thank you!
After that I could overwrite and remove the demo products.
