not found order after payment redirection
i have my custom payment service provider, i successfully send payment request to payment provider but when payment provider redirect customer to payment.url-success i give this error: No order ID available
i check it and find that $session->get( 'aimeos/orderid' ) in the Checkout/Confirm/Order/Standard class return null.
why this happen?
why this happen?
Re: not found order after payment redirection
Is the session cookie not sent by the browser? Google Chrome has introduced a stricter sameSite cookie handling and that causes problems sometimes like the browser doesn't send the cookie to the site even if it should. You can get around that if you send "Set-cookie" explicitely with "SameSite=None".
This article explains how to use it for PHP and Laravel:
https://dev.to/zubairmohsin33/dealing-w ... aravel-pcb
i do that but anything was not change, still when customer redirect from gateway to address ".../shop/confirm/payping-payment" get below error and the basket was cleared:aimeos wrote: ↑02 Sep 2020, 19:55 Is the session cookie not sent by the browser? Google Chrome has introduced a stricter sameSite cookie handling and that causes problems sometimes like the browser doesn't send the cookie to the site even if it should. You can get around that if you send "Set-cookie" explicitely with "SameSite=None".
A non-recoverable error occured
also when i change session.same_site=None and session.secure=true and then try to add product to basket get this exception error:Ahmad wrote: ↑02 Sep 2020, 21:46i do that but anything was not change, still when customer redirect from gateway to address ".../shop/confirm/payping-payment" get below error and the basket was cleared:aimeos wrote: ↑02 Sep 2020, 19:55 Is the session cookie not sent by the browser? Google Chrome has introduced a stricter sameSite cookie handling and that causes problems sometimes like the browser doesn't send the cookie to the site even if it should. You can get around that if you send "Set-cookie" explicitely with "SameSite=None".
https://dev.to/zubairmohsin33/dealing-w ... aravel-pcbhow can i fix it?Code: Select all
No order ID available A non-recoverable error occured
exception: "Symfony\Component\HttpKernel\Exception\HttpException"
file: "C:\xampp\htdocs\shop\vendor\laravel\framework\src\Illuminate\Foundation\Exceptions\Handler.php"
line: 226
message: "CSRF token mismatch."
i still have problem with clearing basket and session when user redirect back from payment gateway.
i explain that when i set same_site = None in session config of laravel this problem was solve but the add to basket and other actions in the shop failed because of csrf token mismatch error,
@aimeos please give me a solution to solve this problem.
You have to whitelist the checkout confirm route:
https://laravel.com/docs/7.x/csrf#csrf-excluding-uris
i think you don't understand my mean, please pay attention to this:aimeos wrote: ↑07 Sep 2020, 10:32 You have to whitelist the checkout confirm route:
i change 'same_site' => 'none' in config/session.php file and secure = true, after this change the problem (session of 'aimeos/orderid' and basket session clear after customer redirect back from payment gateway to shop) was solved but in the other functions of shop application i get errors for "CSRF token mismatch." (for example please see error in attached images that is for when i click on add to basket botton)
- 2020-09-08_12-08-32.jpg (123.14 KiB) Viewed 3140 times
- 2020-09-08_12-08-20.jpg (67.23 KiB) Viewed 3140 times
Maybe you should ask your question in a Laravel forum.
The cookie is available and the token is sent according to your screenshots.
