Multi Vendor Multi-tenant Aimeos Customization
- AstuteDlamini
Is it possible to build my own multi-vendor or multi-tenant eCommerce site using Aimeos or I should just get the marketplace extension?
Re: Multi Vendor Multi-tenant Aimeos Customization
Yes, you can but it will be a lot of work so it's cheaper to buy the market place extension of the Aimeos company.
