Get all products - except those with parents
iresults
Post by iresults » 22 Sep 2020, 18:28
I would like to receive all products that are not assigned to a parent product. With
$manager = \Aimeos\MShop::create($context, 'product');
$expr = $search->compare('==', 'product.type', 'select');
$search->setConditions($expr);
$items = $manager->searchItems( $search );
I get all products with type "select" (all parent products). But how can I retrieve also those products with type "default" who dont have a parent product.
In the end, I need all the products that are displayed in the list by default.
Thanks for a tip.
TYPO3 9.5.x
PHP 7.2
Aimeos 20.7.1
Re: Get all products - except those with parents
Post by aimeos » 23 Sep 2020, 14:46
It's possible but usually you want all products that are at least in one category (default and selection products):
$manager = \Aimeos\MShop::create($context, 'index');
$search = $manager->createSearch(true);
$expr = [
	$search->compare('!=', 'index.catalog.id', null),
	$search->getConditions()
$search->setConditions($search->combine( '&&', $expr));
iresults
Post by iresults » 23 Sep 2020, 17:30
Thank you very much. This is exactly what I was looking for.
parmonov98
Post by parmonov98 » 10 Oct 2020, 09:26
aimeos wrote: 23 Sep 2020, 14:46 It's possible but usually you want all products that are at least in one category (default and selection products):
$expr = [
What is context var here?
How to and what to assign to it?
Post by aimeos » 10 Oct 2020, 09:32
It's the central dependency container. How to retrieve it depends on your environment:
- Laravel: https://aimeos.org/docs/latest/laravel/ ... os-objects
- Symfony: https://aimeos.org/docs/latest/symfony/ ... os-objects
- TYPO3: https://aimeos.org/docs/latest/typo3/ex ... os-objects
