how to add item to cart using ajax?
parmonov98
Post by parmonov98 » 12 Oct 2020, 12:20
I enabled basket-add in config. it works but I need customers to be able add items to cart without going to basket after click add to cart btn.
How can I do that? Once, I read about cline-jsonapi. is that what I need? if yes, please point me again! :) :D
https://imgur.com/CLxmcuM
Re: how to add item to cart using ajax?
Post by aimeos » 13 Oct 2020, 06:47
You can use the JSON API but the easier solution is to use jQuery to display an overlay for the basket.
This is already implemented and works as long as you've not changed the CSS selectors:
https://github.com/aimeos/ai-client-htm ... 1279-L1290
parmonov98
Post by parmonov98 » 16 Oct 2020, 03:42
I'm not willing to use your css and other themes. I'm developing it with my own layouts/templates.
