How to get product stock?
Hello, I need to get the stock value of a product and I'm using the getStockItems function, but I have no results. My code looks like this:
Other functions like getCode () are normal, where am I missing?
$newfunction = function( \Aimeos\MShop\Product\Item\Iface $item ) use ( $fields, $target, $cntl, $action, $config ){
var_dump($item->getStockItems( ));
die();
Re: How to get product stock?
Stock items are only part of the product item if you pass "[..., 'stock']" as second parameter to the search/searchItems method. The list of domains for the second parameter can be configured if you aren't using custom code for that.
