Unable to edit HTML
Unable to edit HTML
I'm attempting to make some changes to the HTML in the checkout pages (if it makes any difference, I have 'onepage' enabled).
I am making changes in the file ext/ai-client-html/client/html/templates/basket/standard/body-standard.php (I want to remove the coupon section).
However, editing this file does nothing. Am I doing this in the wrong place or am I missing a step? I can't find anything specific in the docs.
Re: Unable to edit HTML
First: Don't change the core files! Create your own extension copy the files you want to change and change them there:
https://aimeos.org/docs/latest/frontend ... templates/
If none of your changes is visible, the cache is active (by default). You can disable it during development:
https://github.com/aimeos/aimeos-laravel#hints
Ahh ok - I'd got the idea that the ext/ files are not the core files.
I see now, I'll try that.
It didn't help that I was looking at the wrong file as well
However, creating an extension and copying the files works as advertised. Thanks for the help (again)!
