How to used html-editor in custom page (admin panel)
Dinver
Post by Dinver » 28 Oct 2020, 16:54
I made static-page builder (table/create/edit). With input text/checkbox all understandably. But textarea with vue.component not working.
<textarea class="form-control item-content" required="required"
	:is="html-editor"
	:key="idx"
	:id="cke-idx"
	:value="<?= $enc->html( $this->get( 'itemData/html' ) ); ?>"
	:name="item[html]"
	:tabindex="6"
	v-model="item['html']"
></textarea>
Re: How to used html-editor in custom page (admin panel)
Post by aimeos » 29 Oct 2020, 08:11
Probably this is the problem:
Try instead:
:value="'<?= $enc->attr( $this->get( 'itemData/html' ) ); ?>'"
Note the additional apostrophs!
Dinver
Post by Dinver » 29 Oct 2020, 08:41
aimeos wrote: 29 Oct 2020, 08:11 Probably this is the problem:
Try instead:
Did not help. Does it have he to be additionally init js?
Post by aimeos » 29 Oct 2020, 09:13
Could you remove the colon here:
is="html-editor"
Dinver
Post by Dinver » 30 Oct 2020, 06:10
aimeos wrote: 29 Oct 2020, 09:13 Could you remove the colon here:
is="html-editor"
If moved textarea block to first tab its working. Move in the second tab, not working...
<div class="row item-container">
  <div class="col-md-3 item-navbar">
    <div class="navbar-content">
      <ul class="nav nav-tabs flex-md-column flex-wrap d-flex justify-content-between" role="tablist">
        <li class="nav-item basic">
          <a class="nav-link active" href="#basic" data-toggle="tab" role="tab" aria-expanded="true" aria-controls="basic"><?= $enc->html( $this->translate( 'admin', 'Basic' ) ); ?></a>
        </li>
        <li class="nav-item page">
          <a class="nav-link" href="#page" data-toggle="tab" role="tab" aria-expanded="false" aria-controls="page"><?= $enc->html( $this->translate( 'admin', 'Page' ) ); ?></a>
        </li>
      </ul>
    </div>
  </div>
  <div class="col-md-9 item-content tab-content">
    <div id="basic" class="row item-basic tab-pane fade show active" role="tabpanel" aria-labelledby="basic">
      <div class="col-xl-6 content-block vue-block">
        <!-- forms first tab -->
      </div>
    </div>
    <div id="page" class="row item-page tab-pane fade" role="tabpanel" aria-labelledby="page">
      <div class="form-group row mandatory">
        <div class="col-sm-12">
            is="html-editor"
            key="idx"
            id="cke-idx"
            name="itemData[html]"
            :tabindex="6"
          ></textarea>
        </div>
      </div>
    </div>
  </div>
</div>
Post by aimeos » 31 Oct 2020, 09:43
Each panels is it's own Vue applications. If you add your own one, you need to add a "vue-block" CSS class too to make them a Vue application:
<div class="form-group row mandatory vue-block">
Dinver
Post by Dinver » 03 Nov 2020, 07:08
aimeos wrote: 31 Oct 2020, 09:43 Each panels is it's own Vue applications. If you add your own one, you need to add a "vue-block" CSS class too to make them a Vue application:
Thank you for help! :)
