Catalog media get configuration options
Hi! I wanted to do slider of catalog media. How i can get configuration options?
Dump does not contain this data.
Aimeos\MShop\Media\Item\Standard {#2087 ▼
-langid: "ru"
-prefix: "media."
-available: true
-modified: false
#bdata: array:14 [▼
"media.id" => "33"
"media.siteid" => "1."
"media.languageid" => null
"media.type" => "stage"
"media.url" => "files/8/a/8acc69c8_1669842697.jpg"
"media.label" => "yes.jpg"
"media.status" => "1"
"media.mimetype" => "image/jpeg"
"media.domain" => "catalog"
"media.previews" => array:3 [▼
240 => "preview/8/7/87721256_713301927.jpg"
720 => "preview/2/3/233eee02_679499300.jpg"
1280 => "preview/d/6/d6ed2fd0_1213870932.jpg"
"media.mtime" => "2020-11-04 13:09:06"
"media.editor" => "admin@admin.com"
"media.ctime" => "2020-11-04 12:55:45"
".languageid" => "ru"
-listItems: []
-listRefItems: []
-listRmItems: []
-listPrepared: false
-listRmMap: []
-listMap: []
-listMax: 0
-propItems: []
-propRmItems: []
-propMax: 0
Re: Catalog media get configuration options
These settings aren't part of the media item but of the list item referencing the media item. To get that data, you must use:
foreach( $product->getListItems( 'media', 'default', 'stage' ) as $listItem ) {
$listItem->getConfig(); // all key/value pairs
$listItem->getConfigValue( 'to' ); // single value for 'to'
$listItem->getRefItem(); // media item
I need home page, $product no valueaimeos wrote: ↑07 Nov 2020, 08:18Code: Select all
$this->homeTree->getListItems( 'media', 'default', 'stage' )
Check if
returns an image at all. If not, the images are not loaded at all and there's something wrong. The code that loads the categories and their images is here:
https://github.com/aimeos/ai-client-htm ... #L438-L462
$this->homeTree->getListItems( 'media' )
aimeos wrote: ↑10 Nov 2020, 09:59 Check ifreturns an image at all. If not, the images are not loaded at all and there's something wrong. The code that loads the categories and their images is here:Code: Select all
