Aimeos shop installation error
I have just installed aimeo shop from https://github.com/aimeos for testing.
The version is 2020.10.3
PHP Version I am using is 7.2.10
The package successfully downloaded but when asked for Database credentials I got this error :
Please help how to fix this.
- error.jpg (179.09 KiB) Viewed 1206 times
Re: Aimeos shop installation error
Which composer version do you use? You can check with:
composer -V
Composer version is 2.0.3
This is a bug in composer fixed by:
https://github.com/composer/composer/issues/9421
You need composer 2.0.6 by executing:
composer self-update
Thanks. This fixed the issue and I was able to install.
