Color as a separate product
Hello! I'm new to Aimeos and can't find an easy way to make Color option that on choosing will redirect on frontend to another product with selected color? Currently if i choose Color i still on the same product and there just available change available options on the same page. How to configure product to make this properly in admin panel?
Aimeos 2020.10 LTS
Thanks!
Aimeos 2020.10 LTS
Thanks!
Re: Color as a separate product
As i understand i should create Selector product and then create two Article product with two different colors. But if open one of that Articles product from category list, there is no button like in parent Selector product that can redirect on select to selected second Article product. How to do this properly on back and front end and does it possible?
You should not add variant articles to categories, only the selection product.
We have a video how to create selection products:
https://www.youtube.com/watch?v=S4AgF0wtylM
Thanks for answer!
Yes, but the question is in can somehow i can display two color of, for example, one Shirt as a two different product even it steel a Selection product in categories?
And switch between them in product card like this in demo:
There's no elegant way for that. You can only create a selection product for each article and place a different article at first in each selection product. Thus, you have e.g. five articles and five selection products with a different image and a different article ordering.
Thanks! It's will be very cool, if it will be added to AimeOS in more simple way, i think its pretty useful for many shops
