Catalog pages: high memory consumption and slow load speed
Hi.
The product category page, even if there are no products in it, loads very slowly and uses a lot of memory.
route: /{f_name}~{f_catid}
memory: 47MB
time: 2.5s
total products in the shop: 10500
How i can speed up the loading of category pages?
And how i can view mysql queries of aimeos package?
memory: 47MB
time: 2.5s
Re: Catalog pages: high memory consumption and slow load speed
Sounds like PHP XDebug is enabled in your installation
Thank you for quick answer.
XDebug exists, but it disabled.
For example is product page:
route: /{d_name}/{d_pos?}/{d_prodid?}
memory: 11MB, time: 526ms. It is fast.
Ie problem with catalog pages
On the production server, the speed is also slow. What could be the reason?
Aimeos: 2020.07
PHP: 7.3
Aimeos: 2020.07
PHP: 7.3
Even your detail page isn't really fast and XDebug even consumes resources if it's disabled. Thus, you should deinstall XDebug completely from your production environment.
Then, check the Aimeos Log panel in the admin backend if there are slow queries logged. Also check, if you've disabled caching for Aimeos in the TYPO3 Settings panel (cache driver must be "TYPO3", not "None")
Im using Laravel 7
config/shop.php has:
installed:
"aimeos/ai-cache": "^2020.07"
"predis/predis": "^1.1"
'resource' => [
'cache' => [
'redis' => [
'scheme' => 'tcp',
'host' => '127.0.0.1',
'port' => 6379,
'madmin' => [
'cache' => [
'manager' => [
'name' => 'redis', // Disable caching for development
Can you post your ./config/shop.php (without username/password credentials)?
What happens if you disable Redis caching and use standard DB caching instead?
Nothing happens.
Even after installing aimeos/ai-cache and predis, nothing has changed.
The file is attached.
- shop.php.zip
- (1.8 KiB) Downloaded 295 times
And attached madmin_log of category page: opening and reloading some category page.
Most likely the cache is not working
- madmin_log_2020-11-19 2.sql.zip
- (70.2 KiB) Downloaded 319 times
Queries are fast, the DB seems to be not your problem.
Did you deinstall XDebug?
Yes, I will try to remove xdebug.
But the same problem in production, where xdebug not installed, pages load even slower.
Do you can check my config/shop.php? It seems to me that caching does not work, because when I change the ip address in a redis to a non-existent one, the error does not appear.
