not able to see the list of categories or able to choose them for particular products
I was trying to play with the current system and learn more about it, I was trying to create categories in a dashboard but I was not able to see the list of them or able to choose them for particular products please see below , but I can see them in front end. Would you please help me find out why category is not showing in the dashboard system or if I am doing something wrong here?
PHP Version : 7.4.3
Laravel Framework 6.0.4
Aimeos version": "2020.10.2",
Environment: Win
PHP Version : 7.4.3
Environment: Win
- 3.png (32.3 KiB) Viewed 2112 times
- 2.png (19.85 KiB) Viewed 2112 times
- thumbnail.jpg (97.27 KiB) Viewed 2112 times
Re: not able to see the list of categories or able to choose them for particular products
Most likely, your web server doesn't return a response for the HTTP OPTIONS request. Please open the network console in your browser and check what is returned by the web server.
HI
Thank you for the reply, if I understand your question correctly you mean check this section? if yes how to fix this error? i have the package but it does not find it?
these are what i have in Composer.json
"require": {
"php": "^7.4.3",
"aimeos/aimeos-laravel": "~2020.10.3",
"doctrine/dbal": "^2.9",
"doctrine/migrations": "^3.0",
"fideloper/proxy": "^4.0",
"guzzlehttp/guzzle": "~6.0",
"jeroennoten/laravel-adminlte": "^1.25",
"laravel/framework": "6.0.*",
"laravel/tinker": "^1.0",
"laravel/ui": "^1.0",
"mews/captcha": "^3.0",
"mobiledetect/mobiledetectlib": "^2.8",
"predis/predis": "^1.1",
"rutorika/sortable": "^6.0",
"spatie/laravel-honeypot": "^1.4",
"symfony/orm-pack": "^2.0",
"symfony/psr-http-message-bridge": "^2.0"
"require": {
"php": "^7.4.3",
- Untitled.png (68.91 KiB) Viewed 2043 times
Do you have Laminas Diactoros installed? The Aimeos package requires that by default and your output of "composer show" should contain this:
Your error message looks like one of the packages is missing for a reason we currently don't know.
laminas/laminas-diactoros 2.5.0 PSR HTTP Message implementations
laminas/laminas-zendframework-bridge 1.1.1 Alias legacy ZF class names t...
Thanks for the response, I have installed the 2 new packages but I still can not see the categories and have the same issue.
"require": {
"php": "^7.4.3",
"laminas/laminas-diactoros": "^2.5",
"laminas/laminas-zendframework-bridge": "^1.1",
still having same issue, I don't know why I can not see my categories . is there any way to fix this? as categories are one of the most important part of the system.
"require": {
"php": "^7.4.3",
Can you please post the output of "composer show"?
HI I sent you a private message and replied to the last request few days a go, I just wanted to know if you have received my post?
Maryam
Maryam
Your installed packages are older and you should run "composer update" to get the lastest ones. Maybe it's fixed then. You can also try to remove the ./vendor/ folder completely before executing "composer update". Maybe your installed packages are missing files for an unknown reason.
