put currency sign in front and change numbers to integer
We are using Aimeos version 20.10.1 on a Typo3 v.9.5.21 with php 7.3.19-1~deb10u1 and managed to put some products in. However, for the currency we are using (Chilean Peso) it is required that the currency nominator "$" is in front of the price instead behind the price. Also, we would like to eradicate the decimals and only put the price in integers.
Right now, a price for a product is shown like this: 3.500,00 $
We would like the price be shown like this: $ 3.500
How could we achieve this?
We have found some old questions:
post3191.html#p3191
help-f15/price-format-t3221.html
, but cannot figure out where Locale.php is located in typo3conf/ext/aimeos in order to change at least the decimals from 2 to zero.
Also how to change the currency sign from behind the price numbers to in front of the price numbers provides a challenge for us.
Any hint appreciated.
post3191.html#p3191
aimeos 20.10.4 with aimeos_dist 20.10.1 on Typo3 10.4.12 with php 7.3.19-1 ~ deb10u1
Re: put currency sign in front and change numbers to integer
The precision of the price values can be changed using "mshop/price/precision", i.e.:
The format of the prices is determined by a string that can be translated:
https://aimeos.org/docs/latest/typo3/cu ... anslations
Here's the code that makes the translation:
https://github.com/aimeos/ai-client-htm ... rd.php#L55
Use client as translation domain %1$s %2$s as string and %2$s %1$s as translation. Then, the currency sign and value is swapped.
Make sure you add this also to the scheduler tasks so it will be used for the sent emails too
plugin.tx_aimeos.settings.mshop.price.precision = 0
Thank you very much for the swift answer. I have changed the decimals to 0 adding this to my templates TypoScript Setup:
But when I add the following, there is no change to the order as we want it ( currency first, price second) Could someone point out my error? The template analyzer did not show any abnormalities...
Have a good day!
# set the precision of price values to integer values using mshop.price.precision
# swapping the currency sign with the price value
plugin.tx_aimeos.settings.i18n.es.0 {
domain = client
string = %1$s %2$s
trans = %2$s %1$s
Can you try this instead:
domain = client/code
string = price:default
trans = %2$s %1$s
Brilliant!
Success! Yes, this did the trick. I added the same snippet to our scheduler tasks. Thank you for your support!
