Product counts as more than one
markus.suess@mbit.at
Post by markus.suess@mbit.at » 25 Nov 2020, 16:59
My problem is, that I have products, that count as more than one in stock
I have a combined stock of 1000 pcs
and my products are:
  • Package of 6pcs
  • Package of 10 pcs
  • Package of 20 pcs
So if someone orders 2 20pcs packages, than the overall stock should be minus 40.
Another problem that i have is, that all the products should use the same stock of the 1000 pcs.
How can I configure that in aimeos?
Its a TYPO3 10 installation of aimeos 20
Re: Product counts as more than one
Post by aimeos » 27 Nov 2020, 13:14
You can try the following:
- Create a selection product with three articles (for 6, 10 and 20 pieces)
- Set the quantity scale (extended form in the product detail view) to the apropriate number
Only problem now is that the stock isn't shared and you have to extend Aimeos so the stock level of the selection product is used instead. There may be some things to think about when updating the stock level after an order.
