Need to add new functionality
IOU42
Re: Need to add new functionality
Post by IOU42 » 26 Nov 2020, 08:34
Thanks for that!
The review now indeed accepts empty comment fields, great.
The ratings are still being added on my installation.
Maybe it is because I upgraded to 2020.10.x-dev from a prior version in stead of starting a fresh install.
  • Table mshop_review:
    ratings added.jpg (42.39 KiB) Viewed 1082 times
  • Resulting rating on product page for prod ref id 8 (rate shows 2 x 5)
    rating on producttab.JPG (15.21 KiB) Viewed 1082 times
Cheers, Marc
System info:
Running Aimeos Laravel: 2022.10
Laravel Framework 9.52
Almalinux
PHP 8.1
Post by aimeos » 27 Nov 2020, 13:16
Please keep in mind that you have to add a new review until the rating is recalculated.
IOU42
Post by IOU42 » 30 Nov 2020, 13:00
Hello again, and sorry to be a pain... but I did refresh the review and added new, but still get the rate sum in stead of average?
Please see attachments below where I added another test rating: the 3 ratings now total up to 12 stars...
  • mysql table:
  • Product view:
On the Aimeos demo site all product just have 1 review, so I cannot determine if it is just on my installation ;)
System info:
Almalinux
PHP 8.1
Post by aimeos » 30 Nov 2020, 13:33
Did you updated your installation using:
composer req aimeos/ai-controller-frontend:2020.10.x-dev aimeos/ai-admin-jqadm:2020.10.x-dev
Tested it locally and got the average value as expected, not the sum
