How to aviod HTML Tag removement on text item content
I create text items via
In the Backend, all <tags> are removed. If I enter <tags> in the backend via RTE, the <tags> will be stored without problems.
What should I do to aviod the <tag> replacement/supression?
Thank for your support ans and kind regards, Michael
$newTextItem = $textMgr->create();
$newTextItem->setType('long');
$newTextItem->setDomain('product');
$newTextItem->setLabel('Beschreibung');
$newTextItem->setContent('Text with some html <tags>');
Re: How to aviod HTML Tag removement on text item content
You have to overwrite this configuration in your own file and add the allowed tags:
https://github.com/aimeos/ai-admin-jqad ... min.js#L22
Super, thank you. I'll try this. If I change that in my installation - what would happen on a upgrade of the shop extension?
Add the JS to your own Aimeos extension in ./admin/jqadm/themes/custom.js:
https://aimeos.org/docs/latest/admin/jqadm/customize/
