Attribute sorting [SOLVED]
Hello!
I have one problem with attribute sorting by position or id!
ID and pos (in db) is correct, but on frontend attributes have incorrect position!
Screenshot in attachment!
Best regards,
Goran
// Typo3 10.4.11 / Aimeos 20.10.4 / PHP 7.3 / Linux //
Best regards,
Goran
- frontend-sort.png (23.14 KiB) Viewed 1946 times
- db-sort.png (131.61 KiB) Viewed 1946 times
Re: Attribute sorting
What's the sorting in the attribute subpanel of the product?
in frontend sorting is incorrect!
Re: Attribute sorting [SOLVED]
Here is fix for the problem with correct sort of attributes on product detail page:
In Resources/Private/Extensions/ai-client-html/slient/html/templates/common/partials/attribute-standard.php you need to find 131 line:
<?php if( $this->config( 'client/html/catalog/attribute/preselect/' . $code, false ) === false ) : ?>
<option class="select-option" value=""><?= $enc->html( $this->translate( 'client', 'none' ) ); ?></option>
<?php endif; ?>
add this: <?php ksort($attributes);?>
<?php foreach( $attributes as $id => $attribute ) : ?>
<option class="select-option" value="<?= $enc->attr( $id ); ?>">
<?= $enc->html( $this->attrname( $attribute ) ) ?>
</option>
<?php endforeach; ?>
The attributes are sorted by the order you have added them in the product detail panel of the admin backend, not by the position of the attributes themselves. Thus, you can have a different sorting for different products.
