New site creating commands works in terminal but not from shell_exec() PHP command
command*
$output = shell_exec("cd .. && php artisan aimeos:setup $companyName ");
PHP version 7.3.1
laravel 7
OS - windows
command*
PHP version 7.3.1
laravel 7
OS - windows
Re: New site creating commands works in terminal but not from shell_exec() PHP command
You can use the code for the database setup directly instead of using shell_exec():
https://github.com/aimeos/aimeos-larave ... hp#L60-L72
can you mention the code example for that create a new site with the default attributes under the above situation
$site = '<your new site code>';
$ctx = $this->getLaravel()->make( 'aimeos.context' )->get( false, 'command' );
$config = $ctx->getConfig()->set( 'setup/site', $site );
$dbconfig = $conf->get( 'resource', [] );
foreach( $dbconfig as $rname => $dbconf )
if( strncmp( $rname, 'db', 2 ) !== 0 ) {
unset( $dbconfig[$rname] );
} else {
$conf->set( 'resource/' . $rname . '/limit', 5 );
$taskPaths = $this->getLaravel()->make( 'aimeos' )->get()->getSetupPaths( 'default' );
$manager = new \Aimeos\MW\Setup\Manager\Multiple( $ctx->getDatabaseManager(), $dbconfig, $taskPaths, $ctx );
$manager->migrate( $task );
$site = $this->argument( 'site' );
} else {
What do you mean? What are "attributes of the default site"?
In the admin panel, there is tab called types in that tab contain the attribute, catalog lists, media, plugins, and lot more... and each table contain their own attributes [ex:- Domain:media, code:default, label:Standard].
php artisan aimeos:setup <new site code>
when I create a new site using this command, the new site is generated with those attributes which are in the default site that I mentioned above. but I want to generate a new site with those attributes in a single button click. to achieve that goal I tried running this shell command
hopefully, the site is generated with attributes but it didn't work and shows error 404 not found.
I don't know the easiest way to achieve this.
It should work because of this line:
It uses the setup tasks for "default" which also creates the types.
The latest Aimeos distribution includes seller registration out of the box and you can use this code as reference:
https://github.com/aimeos/aimeos/blob/m ... er.php#L75
