Cannot add products after database refresh
I needed to recreate the database so I dropped all tables and re-created them using "php artisan aimeos:setup".
After that I created a few sites under default.
Now when I am trying to add products to my sites I get this error message on save:
Item Successfully saved.
and then
Item with ID "8" in "product.id" not found When I check the product table, record is added. But it is not shown in Admin panel.
Can someone please help what I have missed.
Laravel 8
PHP 7.4
Aimeos 2020.10
MariaDB
and then
Laravel 8
PHP 7.4
Aimeos 2020.10
MariaDB
Re: Cannot add products after database refresh
Hard to say without knowing your setup and customizations. A stack trace of the exception would be helpful.
Managed to solve the issue !
