How to access Aimeos Admin login/Admin panel (Laravel 8 -Jetstream) PHP 7.3
i just installed laravel 8 with jetstream and i went through the aimeos installation documentation on GitHub to install aimeos in to laravel
after successful installation, /admin sends me to laravel default scaffold dashboard.
I then changed the codes in the web.php
to
when i reloaded the page, i get an error that The page isn’t redirecting properly
I need help. Thanks in advance
to
Route::middleware(['auth:sanctum', 'verified'])->get('/admin', '\Aimeos\Shop\Controller\AdminController@indexAction')->name('admin');
Re: How to access Aimeos Admin login/Admin panel (Laravel 8 -Jetstream) PHP 7.3
The problem is most likely that you've added 'auth:sanctum' to the /admin route instead of the jqadm and jsonadm route:
https://github.com/aimeos/aimeos-larave ... hp#L12-L14
I am having the same issue
my roite file web.php
<?php
use Illuminate\Support\Facades\Route;
| Web Routes
| Here is where you can register web routes for your application. These
| routes are loaded by the RouteServiceProvider within a group which
| contains the "web" middleware group. Now create something great!
Route::group(['middleware' => ['web']], function () {
Route::get('/', '\Aimeos\Shop\Controller\CatalogController@homeAction')->name('aimeos_home');
Route::middleware(['auth:sanctum', 'verified'])->get('/dashboard', function () {
return view('dashboard');
})->name('dashboard');
Seems like Laravel looses the /admin URL stored in the session for redirecting after login for some reason if you go to
and log in using Sanctum.
http://127.0.0.1:/admin
why dont u go and fix this ?aimeos wrote: ↑13 Aug 2021, 07:08 Seems like Laravel looses the /admin URL stored in the session for redirecting after login for some reason if you go toand log in using Sanctum.Code: Select all
We don't kno why this happens yet. Hints and/or patches are highly welcome!
