Selection product not importing properly in CSV Import
I am using Sample CSV file for import.
There are no errors on import and the products are added to tables.
But the variants are not being added. Here are the screen shots. My shop.php is :
CSV file is attached.
What I am missing here, please help.
'controller' => [
'jobs' => [
'product' => [
'import' => [
'csv' => [
'location' => public_path() . '/tmp',
'skip-lines' => 1,
'container' =>[
'type' => 'Directory',
'content' => 'CSV',
'mapping' => [
'item' => [
1 => 'product.label', // UTF-8 encoded text, also used as product name
2 => 'product.type', // type of the product, e.g. "default" or "selection"
3 => 'product.status', // enabled (1) or disabled (0)
'text' => [
4 => 'text.type',
5 => 'text.content',
6 => 'text.type',
7 => 'text.content',
'media' => [
8 => 'media.url',
'price' => [
9 => 'price.currencyid',
10 => 'price.quantity',
11 => 'price.value',
12 => 'price.taxrate',
'attribute' => [
13 => 'attribute.code',
14 => 'attribute.type',
'product' => [
15 => 'product.code',
16 => 'product.lists.type',
'property' => [
17 => 'product.property.value',
18 => 'product.property.type',
'catalog' => [
19 => 'catalog.code', // e.g. Unique category code
20 => 'catalog.lists.type', // e.g. "promotion" for top seller products
- products-import-example.zip
- (528 Bytes) Downloaded 103 times
Re: Selection product not importing properly in CSV Import
Did you create the attributes first? The product CSV import doesn't do that automatically if you forgot to add them before.
The documentation says that attributes are automatically created.
"Nevertheless, if an attribute doesn't exist, it will be created automatically."
"size" attribute was already added.
"S/M" & "M/L" no. But I also tried adding them. Still same result.
I can see the attributes in list if I try to manually add them.
OK, then it's the missing product.lists.type column for each attribute type/value pair column with the value "variant" so the attributes are added as variant attributes instead of regular attributes. Instead of:
Use:
attribute.type;attribute.code;attribute.type;attribute.code
size;M/L;color;blue
product.lists.type;attribute.type;attribute.code;product.lists.type;attribute.type;attribute.code
variant;size;M/L;variant;color;blue
Thanks alot.
Yes, this fixed the issue.
