add product to basket shows out of stock error
- Advanced
We are using two stores on aimeos now. With one store everything is working fine. But, with new store. when we try to add product to basket, it is returning out of stock error for every products.
This error is happening 3/10 time. We are not able to find actual reason behind it. Once it will come for the user, then same user will get error for every products until we remove user from store and he will register again.
We are using aimeos laravel and connect it to mobile application on android and ios platform.
Thanks in advance
Tejas
Thanks in advance
Tejas
Re: add product to basket shows out of stock error
There's most likely a siteid value mismatch between your stock and user records. If you want your user records to be available for all sites, make sure they have a siteid of "" (empty string instead of e.g. "2.").
