How to make changes in front-end
ArthurHenrique
Post by ArthurHenrique » 03 Feb 2021, 18:07
I need to make some changes in front-end, change the logo, color of the backgrounds, etc. I found the css arquives but I dont understand how modifier the html structure.
Enviroment:
Windows 10
PHP = 7.2
Laravel = 6.0
Aimeos = 2020.10
Re: How to make changes in front-end
Post by aimeos » 05 Feb 2021, 09:18
willy
Post by willy » 22 Apr 2021, 10:05
aimeos wrote: 05 Feb 2021, 09:18 Have you read this article?
https://aimeos.org/docs/latest/frontend ... te-themes/
yes but I still don't understand how to change the default logo. I tried to change the following path:
<img src = "https://aimeos.org/fileadmin/template/icons/logo.png" height = "30" title = "Aimeos Logo">
But it does not work.
Post by aimeos » 24 Apr 2021, 09:26
The logo is defined in the ./resources/views/app.blade.php template.
Rogahnd
Post by Rogahnd » 12 Aug 2021, 04:20
I'm always wondering if there's a checklist of steps to complete in building a full website using Laravel.
I always feel like there's a ton to do (backend, frontend, languages, views, packages, models, controllers, you get the point).
Where do you start? Do you follow a method? or go random between all of the above, I go randomly, and would love to change to a better method, one where I can measure progress and check off items on a todo list. Looking forward to your responses.
ArthurHenrique
Post by ArthurHenrique » 12 Aug 2021, 13:43
I'm learning how to use PHP and Laravel for a job in the company where I work, honestly I'm not interested in web development , so I cant help you with my opinion, but there are many developers that can help you with this point at stack overflow for example. Good luck!
