price filter under category
- GülsümAkça
I want to use the price filter only under a certain category. For example, just list products under $ 100 in the women's category. can you help me.
thanks
thanks
Re: price filter under category
1.) Create your own extension: https://aimeos.org/extensions
2.) Overwrite the template for the catalog lists page: https://aimeos.org/docs/latest/frontend ... templates/
3.) Add a condition to that template based on the category ID you get by using
$catid = $this->param('f_catid')
- GülsümAkça
I solved the problem by adding this line to the catalog/ filter/body-standard.php page. Thankyou for your help.
<?php if ($this->param('f_catid')) : ?>
<input type="hidden" name="f_catid" value="<?=$this->param('f_catid')?>" >
<?php endif; ?>
