Products only on specifiy days of the week
I'm pretty new to aimeos and so far I haven't found what I needed in the documentation. First of all my setup:
Laravel: 6.20.15
PHP: 7.4.7
Aimeos: 2020.10
Mac
I want to display certain products only on certain days. For example: Article 1 should only be available on Mondays and Tuesdays... Is that possible with aimeos, without having to set it to disabled manually?
Thanks for the help!
Laravel: 6.20.15
PHP: 7.4.7
Aimeos: 2020.10
Mac
Re: Products only on specifiy days of the week
Not on weekdays. You can limit products to a certain timeframe using the start date and the end date that's available for each product instead:
Thanks for your answer =)
