Setup new entity for jsonadm
- Expert
Hi community!
I need to integrate something like pages manager, with nested levels to show them on frontend menu. For this purpose I think catalog entity suits pretty well. I have copied all files from catalog (manager, standard, item, templates). And of course have renamed catalog to page everywhere. So I got the page item in back-end menu. No errors. I have attached the image with result. But items not loading. I think I have to configure jsonadm or something like this. Because I see, there are some ajax calls and no needed data come from server.
I will be very thankful for some clarifications or tips!
These are the components versions:
aimeos/ai-admin-jqadm 2020.10.6 Aimeos Vue.js+Bootstrap admin interface
aimeos/ai-admin-jsonadm 2020.10.1 Aimeos ai-admin-jsonadm extension
aimeos/ai-client-html 2020.10.8 Aimeos ai-client-html extension
aimeos/ai-client-jsonapi 2020.10.3 Aimeos JSON API extension
aimeos/ai-controller-frontend 2020.10.1 Aimeos ai-controller-frontend extension
aimeos/ai-controller-jobs 2020.10.4 Aimeos ai-controller-jobs extension
aimeos/ai-gettext 2020.10.1 Aimeos Gettext extension
aimeos/ai-laravel 2020.10.2 Laravel adapter for Aimeos web shops and e-commerce solutions
aimeos/ai-swiftmailer 2020.10.1 SwiftMailer adapter for Aimeos web shops and e-commerce solutions
aimeos/aimeos-core 2020.10.7 Full-featured e-commerce components for high performance online shops
aimeos/aimeos-laravel 2020.10.3 Professional, full-featured and high performance Laravel e-commerce package for online shops and complex B2B projects
aimeos/map 1.10.0 Easy and elegant handling of PHP arrays as array-like map objects similar to jQuery and Laravel Collections
- Screenshot from 2021-02-04 14-18-13.png (6.12 KiB) Viewed 1037 times
Re: Setup new entity for jsonadm
You need to implement a JSON REST endpoint for your page manager like the catalog endpoint in the jsonadm extension:
https://github.com/aimeos/ai-admin-json ... in/JsonAdm
- Expert
Thanks, that works. But another problem, the aimeos node means only one root entity and then the tree under root entity. Is it possible to customize it to have several entities on top and each may have own tree.
I mean I have created page entity on catalog example.
but it works like this structure:
rootPage
-firstPage
--second
-third
But I want to have like this:
firstPage
-nested
--nested
secondPage
-nested
--nested
The second structure would allow me to integrate menu manager to my aimeos installation. Because sometimes I need simple cms just to manage pages and menu. And I don't want to mix it with other packages, I want to make it in same style with aimeos. Please give me some tips..
Thank you !
rootPage
-firstPage
--second
-third
firstPage
-nested
--nested
secondPage
-nested
--nested
Thank you !
