price without decimals
Hi!
Is there any way to configure in one place to use price without decimals? e.g. 1000 usd
Re: price without decimals
You can set the price precision using:
More info:
https://github.com/aimeos/aimeos-core/b ... #L183-L194
See also:
https://aimeos.org/docs/latest/laravel/ ... figuration
mshop/price/manager/precision => 0
See also:
Thanks!
A small note.
My version of aimeos-core/lib/mshoplib/src/MShop/Price/Manager/Standard.php has a little bit different config string:
$this->precision = $context->getConfig()->get( 'mshop/price/precision', 2 ); (not 'mshop/price/manager/precision'): see attach.
So when I update the core I will loose this config. Probably it would be good either do not change config strings in future versions or make some kind of compatibility.
A small note.
- Screenshot_27.jpg (32.12 KiB) Viewed 1027 times
