Save Basket API Response Issue
danishrehman
Post by danishrehman » 05 Dec 2020, 09:31
Aimeos Version: 2020.10
Php Version: 7.3.4
Environment: Win 10 (wamp server)
I'm working on API where saving basket after adding products, address and services!
axios.post('/jsonapi/basket').then(response => {
        console.log(response)
}).catch(error => {
         console.log(error)
This below error comes up in response every time, configured everything as in documentation mentioned. Please let me know where I go wrong. Thanks
Error!
Checks for available service items in basket failed.
Re: Save Basket API Response Issue
Post by aimeos » 06 Dec 2020, 18:01
Do you pass the CSRF token and the session token in your request?
Can you please add more details like last response and full source code for your request?
danishrehman
Post by danishrehman » 07 Dec 2020, 05:57
No, Its not the issue of CSRF!
First of all adding product to basket, and its working.
addToBasket: function () {
                let data = {
                    "data": [
                            "attributes": {
                                "product.id": "1",
                                "quantity": 1,
                                "stocktype": "default"
                axios.post('/jsonapi/basket?id=default&related=product',data).then(response => {
                    console.log(response);
                }).catch((error) => {
then adding address, its working too.
let address = {
                    "data": [
                            "id": "payment",
                            "attributes": {
                                "order.base.address.firstname": "Walk-in",
                                "order.base.address.lastname": "Customer",
                                "order.base.address.salutation": "mr",
                                "order.base.address.title": "Dr.",
                                "order.base.address.postal": "51310",
                                "order.base.address.countryid": "PK",
                                "order.base.address.address1": "Main Market Street",
                                "order.base.address.city": "Sialkot",
                                "order.base.address.languageid": "en",
                                "order.base.address.email": "danidff@gmail.com",
                axios.post('/jsonapi/basket?id=default&related=address',address).then(response => {
Then adding to services, It's working as well!
 let service = {
                    "data": [
                            "id": "payment",
                            "attributes": {
                                /*"service.id": "11",*/
                                "service.id": 6,
                axios.post('/jsonapi/basket?id=default&related=service&relatedid=payment', service).then(response => {
                }).catch(error => {
In last when i call for save basket to generate order, error comes up!
axios.post('/jsonapi/basket?id=default').then(response => {
                  console.log(error)
}).catch(error => {
                    console.log(error)
Error!
EXPLAINATION
It working fine when I off these two plugins but issue is, if go for it order doesn't save.
  • Checks for required addresses (billing/delivery)
  • Checks for required services (delivery/payment)
Post by aimeos » 08 Dec 2020, 09:46
Does the response you get after adding the delivery/payment services contains all data you've added before?
danishrehman
Post by danishrehman » 09 Dec 2020, 06:33
yes, it does contain all data getting response as success.
I've mentioned two default plugins are conflicting with Save Basket! I've off both of plugins temporary but does not save record in base_order table else saving good.
Just need clarity on this issue how to resolve this issue on my end. Can your team check this issue?
Many Thanks in advance.
Post by aimeos » 11 Dec 2020, 11:15
Which application (Laravel, Symfony or TYPO3) are you using? We had problems in the past with MySQL based user sessions. File based session never had problems.
danishrehman
Post by danishrehman » 11 Dec 2020, 12:17
I'm currently using laravel based store as default plus creating POS with vue js!
issue is on save basket end point of api. which is conflicting with two mentioned plugins or something is missing in doc that how to handle.
Post by aimeos » 11 Dec 2020, 12:38
The plugis error messages are only the result of an empty basket but not the cause of the problem. Like said, we had problems in the past with baskets being empty between request. Add another request fetching the complete basket so you can check if it's empty or at least addresses and services missing before you try to sent a POST request to persist the basket.
hassanas
Post by hassanas » 24 Feb 2021, 10:57
I am facing the same problem and I am receiving empty response (after add to cart call) on every subsequent call. I am not passing any kind of token or cookie ? what I have to do? please share some code snippet
Post by aimeos » 26 Feb 2021, 07:41
You need to pass the session cookie and the CSRF token (if you want to update the basket):
https://aimeos.org/docs/latest/frontend ... i/baskets/
