CMS extension
Re: CMS extension
Please use dev-master, we've renamed the branch to be in line with all others.
- Expert
Re: CMS extension
ok, I have updated the components. But when I clicked to add new content item I got JS error
And the page is not displayed in tree (
Seems tree is not implemented yet ?
JS error seems related to this file
https://github.com/aimeos/ai-cms-grapes ... /custom.js
line 199,
I will try to fix JS grapejs error with my custom extension, but why the editor looks such empty ? I thought there should be more functions etc )
line 199,
buttons : [{
/* id: 'open-sm',
command: 'open-sm',
className: 'fa fa-paint-brush',
*/ id: 'open-tm',
command: 'open-tm',
className: 'fa fa-cog',
/* id: 'open-layers',
command: 'open-layers',
className: 'fa fa-bars',
*/ id: 'open-blocks',
command: 'open-blocks',
className: 'fa fa-th-large',
active: true,
- Screenshot from 2021-02-24 15-46-12.png (135.08 KiB) Viewed 10204 times
- Expert
Re: CMS extension
I tried to extend cms table:
But got error:
schema from my custom extension is executed before the grapesjs extension's schema.. I think it is the cause. But why my extension is first ? In the ext folder my extension is on last place
return [
'table' => [
'mshop_cms' => function ( \Doctrine\DBAL\Schema\Schema $schema ) {
$table = $schema->getTable( 'mshop_cms' );
$table->addColumn( 'parentid', 'integer', ['notnull' => false] );
$table->addColumn( 'level', 'smallint', [] );
$table->addColumn( 'nleft', 'integer', [] );
$table->addColumn( 'nright', 'integer', [] );
return $schema;
Doctrine\DBAL\Schema\SchemaException : There is no table with name 'aimeosdev.mshop_cms' in the schema.
Re: CMS extension
Tried on a fresh installation with aimeos/ai-cms-grapesjs:dev-master and it works without any JS error. The error causes that the panels on the right are not displaed.MikaelNazarenko wrote: ↑24 Feb 2021, 13:48 ok, I have updated the components. But when I clicked to add new content item I got JS error
No, that's up to you.MikaelNazarenko wrote: ↑24 Feb 2021, 13:48 And the page is not displayed in tree (
Re: CMS extension
The order in the ext folder doesn't matter, only the dependencies in the "depends" section in the manifest.php file of your extension. But you need to add your schema update and your code for displaying the tree directly to the ai-cms-grapesjs extension so it will be included by default in the future.MikaelNazarenko wrote: ↑24 Feb 2021, 19:36 schema from my custom extension is executed before the grapesjs extension's schema.. I think it is the cause. But why my extension is first ? In the ext folder my extension is on last place
- Expert
Re: CMS extension
Ok, thanks! I got it) I will make pull requests later, after I test it with my custom extension)
- Expert
Re: CMS extension
You said:
"But you need to add your schema update and your code for displaying the tree directly to the ai-cms-grapesjs extension so it will be included by default in the future"
But why I can't extend mshop_cms page with normal way in my extension? Why do I get the error? You did not add some config for mshop_cms somewhere ? Because I am able to extend users, order, product and other aimeos tables..
Re: CMS extension
You can but then it won't be in the aimeos/ai-cms-grapesjs extension. Instead of implementing it just for you, please create a PR with the changes in the aimeos/ai-cms-grapesjs extension so it will be available for all.MikaelNazarenko wrote: ↑01 Mar 2021, 11:50 But why I can't extend mshop_cms page with normal way in my extension? Why do I get the error? You did not add some config for mshop_cms somewhere ? Because I am able to extend users, order, product and other aimeos tables..
The error you've described is caused by a wrong execution order due to a missing dependency in you manifest.php file. If you add "ai-cms-grapesjs" in the "depends" section of your manifest.php file, that the order will be correct and the "mshop_cms" table will be available.
- Expert
Re: CMS extension
This is my manifest.php:
<?php
And still this error
<?php
return array(
'name' => 'custom',
'depends' => array(
'aimeos-core',
'ai-admin-jqadm',
'ai-admin-jsonadm',
'ai-client-html',
'ai-client-jsonapi',
'ai-controller-jobs',
'ai-controller-frontend',
'ai-cms-grapesjs'
'include' => array(
'lib/custom/src',
'client/html/src',
'client/jsonapi/src',
'controller/common/src',
'controller/frontend/src',
'controller/jobs/src',
'admin/jsonadm/src',
'admin/jqadm/src',
'i18n' => array(
'admin' => 'admin/i18n',
'admin/jsonadm' => 'admin/jsonadm/i18n',
'client' => 'client/i18n',
'client/code' => 'client/i18n/code',
'controller/common' => 'controller/common/i18n',
'controller/frontend' => 'controller/frontend/i18n',
'controller/jobs' => 'controller/jobs/i18n',
'mshop' => 'lib/custom/i18n',
'config' => array(
'config',
'custom' => array(
'admin/jqadm' => array(
'admin/jqadm/manifest.jsb2',
'admin/jqadm/templates' => array(
'admin/jqadm/templates',
'admin/jsonadm/templates' => array(
'admin/jsonadm/templates',
'client/html/templates' => array(
'client/html/templates',
'client/jsonapi/templates' => array(
'client/jsonapi/templates',
'controller/jobs' => array(
'controller/jobs/templates' => array(
'controller/jobs/templates',
'setup' => array(
'lib/custom/setup',
Re: CMS extension
We've found the problem:
The name in the manifest.php file was still "ai-cms-grapejs" instead of "ai-cms-grapesjs". This has been fixed now and adding columns should work now.
