How to switch the Aimeos locale sites according to the User's country.
usernew
Post by usernew » 25 Feb 2021, 05:17
I have a shop with 2 Aimeos locale sites: default and default1. both have a different set of products.
I want to display the items from default1 if the user is from country A . and if they are from country B , I need to show the products from default.
How can I switch the sites according to the IP of user.(to get the country).
I hope you can help me.
Thank you.
Re: How to switch the Aimeos locale sites according to the User's country.
Post by aimeos » 26 Feb 2021, 09:32
You may use the TYPO3 locate extension to map the IP to the country. Then, you can extend the Aimeos Locale class and use the country to set the site code you want:
https://github.com/aimeos/aimeos-typo3/ ... hp#L32-L47
To use your new Locale class, add a configuration in your own TYPO3 extension (use the Aimeos extension generator to create one) like described here:
https://aimeos.org/docs/latest/typo3/ex ... strap-code
