How to get getRefItems('product') of bought together in catalog/detail?
mr.zherart
Post by mr.zherart » 31 Mar 2021, 14:06
Hello, Aimeos.
My version is Laravel 2020.10.
Seems it is no way to get subproducts (or other) referenced items for bought together products on catalog detail? I need to get products on the "select" type product, but it is empty.
I can get bought-together items via:
$boutghtItems = $detailProductItem->getRefItems('product', null, 'bought-together');
but in foreach for $boutghtItem will empty for select type.
$boutghtItem->getRefItems('product', 'default', 'default')
I tried to set up the product domain in any related manager for getting it, but it does not work.
Can you help please, how to do it, or what I do wrong? Thank you!
Re: How to get getRefItems('product') of bought together in catalog/detail?
Post by aimeos » 02 Apr 2021, 17:21
There's a decorator to prevent fetching huge amount of data accidentially or worse, being trapped in a recursion due to two products referencing each other. You can change the maximum depth of retrieving referenced items by configuration:
https://github.com/aimeos/aimeos-core/b ... hp#L40-L56
mr.zherart
Post by mr.zherart » 04 Apr 2021, 13:33
Thank you, I changed config maxdepth from 2 to 3, and all working great now!
