issues in Implementing Delivery Provider
Re: issues in Implementing Delivery Provider
Hey guys waiting for reply
hey guys please have a look at this problem
Your code looks correct.khizar wrote: ↑07 Apr 2021, 11:39Code: Select all
if($t->data[0]->success){ // here is the code for saving attributes $status = \Aimeos\MShop\Order\Item\Base::STAT_PROGRESS; $order->setDeliveryStatus( $status ); // $this->saveOrder( $order ); $attributes = ['reference_number' => $t->data[0]->reference_number]; $serviceType = \Aimeos\MShop\Order\Item\Base\Service\Base::TYPE_DELIVERY; $orderServiceItem = $order->getService( $serviceType ); $this->setAttributes( $orderServiceItem, $attributes, 'myprovider' ); $this->saveOrderBase( $basket ); } return $order; } }
In the order list view it's more difficult because the order details are not loaded there:khizar wrote: ↑07 Apr 2021, 11:39 Now if above code is right can you please tell me how can i access that reference no in orders listplease note that the above foreach loop is from the orders list and it contains code but for the sake of simplicity i picked up only start and end of the loop can you please tell me here how can i access that reference numberCode: Select all
<?php foreach( $this->get( 'items', [] ) as $id => $item ) : ?> <?php endforeach; ?>
https://github.com/aimeos/ai-client-htm ... d.php#L218
You would have to overwrite that method with your own version in your own extension and use:
$view->listsOrderItems = $cntl->uses( ['order/base', 'order/base/service'] )->sort( '-order.id' )->search();
if( $service = current( $item->getBaseItem()->getService( 'delivery' ) ) ) {
$ref = $service->getAttribute( 'reference_number', 'myprovider' );
Note: We answer questions in the forum in our spare time.
If you need immediate response, please ask the Aimeos company for paid support:
https://aimeos.com/support
I have completed my task .I want to you to have a look at my code and guide me is it correct or not so that i can move on to next task .i am getting my desired result but not sure my approach is right or not so please guide me.i am posting my code belowaimeos wrote: ↑09 Apr 2021, 07:08Your code looks correct.khizar wrote: ↑07 Apr 2021, 11:39Code: Select all
You would have to overwrite that method with your own version in your own extension and use:Then, you can get the reference in the loop using:Code: Select all
https://github.com/aimeos/aimeos-core/b ... e.php#L151Code: Select all
if( $service = current( $item->getBaseItem()->getService( 'delivery' ) ) ) { $ref = $service->getAttribute( 'reference_number', 'myprovider' ); }
<?php
namespace Aimeos\MShop\Service\Provider\Delivery;
use Illuminate\Support\Facades\DB;
use Illuminate\Support\Facades\Http;
use Illuminate\Support\Facades\Log;
class Myprovider
extends \Aimeos\MShop\Service\Provider\Delivery\Base
implements \Aimeos\MShop\Service\Provider\Delivery\Iface
* Sends the order details to the ERP system for further processing.
* @param \Aimeos\MShop\Order\Item\Iface $order Order invoice object to process
public function process(\Aimeos\MShop\Order\Item\Iface $order): \Aimeos\MShop\Order\Item\Iface
$parts = \Aimeos\MShop\Order\Item\Base\Base::PARTS_ALL;
$basket = $this->getOrderBase($order->getBaseId(), $parts);
$data = []; // note that it contains data but i have skipped that part
$apiurl = 'http://demodashboardapi.shipsy.in/api/customer/integration/consignment/softdata';
$response = Http::withHeaders([
"api-key" => "XXXXXXXXXXXXXX",
"Content-Type" => "application/json"
])->post($apiurl,$data);
$t = json_decode($response);
info('entered into success method');
$attributes = ['reference_number' => $t->data[0]->reference_number,'message'=>''];
$orderServiceItem = $basket->getService( $serviceType );
if(($serviceItem = reset($orderServiceItem)) !== false){
$this->setAttributes( $serviceItem, $attributes, 'myprovider' );
}else{
$attributes = ['reference_number' => '', 'message' => $t->data[0]->message];
return $order;
<?php
$baseItems = $this->get( 'baseItems', [] );
$baseItem = ( isset( $baseItems[$item->getBaseId()] ) ? $baseItems[$item->getBaseId()] : null );
$reference_no = '';
$message = '';
$orderServiceItem = $baseItem->getService( $serviceType );
$reference_no = $serviceItem->getAttribute( 'reference_number', 'myprovider' );
// $attrItem = $serviceItem->getAttributeItem( 'reference_number', 'myprovider' );
$message = $serviceItem->getAttribute( 'message', 'myprovider' );
endforeach:
