Login API
veeran ambalam
Login API
Post by veeran ambalam » 10 Apr 2021, 05:12
I am a newbie to laravel and Aimeos, It seems there is no documentation for login API, So If there is an idea of how to do it, kindly share me. I tried using the same login controller and authenticate but when I try to get customer details it returns null
Re: Login API
Post by aimeos » 11 Apr 2021, 12:10
Authentication is handled by Laravel resp. Lararvel packages like Passport or Sanctum and you have to read their documentation to set up API authentication for Laravel.
veeran ambalam
Re: Login API
Post by veeran ambalam » 11 Apr 2021, 16:57
Yes I used Passport, created an access token using but when I use it for customer API it returns null, I dont am i doing it the right way.
Route::post('login-app', [AccessTokenController::class, 'issueToken'])->middleware(['api-login', 'throttle']);
const config = {
headers: {
"Content-type": "application/json",
"Authorization": `Bearer ${this.state.access_token}`,
axios.get("http://localhost:8000/jsonapi/customer", null, config)
.then((response) => {
console.log(response.data);
.catch((err) => {
console.log(err);
Re: Login API
Post by aimeos » 11 Apr 2021, 17:01
Do you send the Laravel session token with your request?
