retrieve attributes-orders
hello aimeos,
i have integrated aimeos with laravel.
versions:
"aimeos/aimeos-laravel": "~2020.10",
"laravel/framework": "^8.12",
I have implemented Delivery service provider perfectly my problem is that i stored the tracking id of order which is returned from delivery api in order.i am posting the code below.
it sends order successfully and also attribute is saved as order service attribute .I can see in my data base.Now i want to retrieve that reference number in the order list but i don't know how to do it .i am posting the code of orderlist below
Please note that this is the code from orders list(file name: list-standard).it contains more code but i have only picked the necessary code.that dd gives me
now from here i dont know how can i access the service attribute
versions:
<?php
namespace Aimeos\MShop\Service\Provider\Delivery;
use Illuminate\Support\Facades\DB;
use Illuminate\Support\Facades\Http;
use Illuminate\Support\Facades\Log;
class Myprovider
extends \Aimeos\MShop\Service\Provider\Delivery\Base
implements \Aimeos\MShop\Service\Provider\Delivery\Iface
* Sends the order details to the ERP system for further processing.
* @param \Aimeos\MShop\Order\Item\Iface $order Order invoice object to process
public function process(\Aimeos\MShop\Order\Item\Iface $order): \Aimeos\MShop\Order\Item\Iface
$parts = \Aimeos\MShop\Order\Item\Base\Base::PARTS_ALL;
$basket = $this->getOrderBase($order->getBaseId(), $parts);
// here is the code which i have skipped which contains $data array which i have sent to the api
$apiurl = 'http://demodashboardapi.shipsy.in/api/customer/integration/consignment/softdata';
$response = Http::withHeaders([
"api-key" => "xxxxxxxxxxxxxxxxxxxx",
"Content-Type" => "application/json"
])->post($apiurl,$data);
$t = json_decode($response);
if($t->data[0]->success){
// $status = \Aimeos\MShop\Order\Item\Base::STAT_PROGRESS;
// $order->setDeliveryStatus( $status );
// $this->saveOrder( $order );
$attributes = ['reference_number' => $t->data[0]->reference_number];
$serviceType = \Aimeos\MShop\Order\Item\Base\Service\Base::TYPE_DELIVERY;
$orderServiceItem = $basket->getService( $serviceType );
if(($serviceItem = reset($orderServiceItem)) !== false){
$this->setAttributes( $serviceItem, $attributes, 'myprovider' );
$this->saveOrderBase( $basket );
return $order;
$baseItems = $this->get( 'baseItems', [] );
<?php foreach( $this->get( 'items', [] ) as $id => $item ) : ?>
<?php $baseItem = ( isset( $baseItems[$item->getBaseId()] ) ? $baseItems[$item->getBaseId()] : null ); ?>
dd($baseItem->getServices())
<?php endforeach: ?>
Aimeos\Map {#1836 ▼
#list: array:2 [▼
"delivery" => array:1 [▼
0 => Aimeos\MShop\Order\Item\Base\Service\Standard {#1591 ▼
-serviceItem: null
-attributes: []
-attributesMap: null
-price: Aimeos\MShop\Price\Item\Standard {#1550 ▶}
-prefix: "order.base.service."
-available: true
-modified: false
#bdata: array:19 [▼
"order.base.service.id" => "15"
"order.base.service.baseid" => "12"
"order.base.service.siteid" => "17."
"order.base.service.serviceid" => "7"
"order.base.service.type" => "delivery"
"order.base.service.code" => "shipsy"
"order.base.service.name" => "shipsy"
"order.base.service.mediaurl" => ""
"order.base.service.currencyid" => "SAR"
"order.base.service.price" => "0.00"
"order.base.service.costs" => "37.50"
"order.base.service.rebate" => "0.00"
"order.base.service.taxvalue" => "0.3713"
"order.base.service.taxrates" => array:1 [▶]
"order.base.service.taxflag" => "1"
"order.base.service.position" => "0"
"order.base.service.mtime" => "2021-04-08 08:08:25"
"order.base.service.editor" => "127.0.0.1"
"order.base.service.ctime" => "2021-04-08 08:08:25"
"payment" => array:1 [▼
1 => Aimeos\MShop\Order\Item\Base\Service\Standard {#1594 ▼
-serviceItem: null
-attributes: []
-price: Aimeos\MShop\Price\Item\Standard {#1556 ▶}
-available: true
-modified: false
#bdata: array:19 [▼
"order.base.service.id" => "16"
"order.base.service.serviceid" => "8"
"order.base.service.type" => "payment"
"order.base.service.code" => "cash"
"order.base.service.name" => "cashondelivery"
"order.base.service.costs" => "15.00"
"order.base.service.taxvalue" => "0.1485"
"order.base.service.position" => "1"
Re: retrieve attributes-orders
