Syntax Error
Syntax Error
In the file:
vendor\aimeos\aimeos-core\lib\mshoplib\setup\StockMigrateProductId.php
This syntax is not correct for POSTGRESQL:
the correct syntax like :
Tank you
In the file:
'unq_mssto_sid_pcode_ty' => 'DROP INDEX "unq_mssto_sid_pcode_ty" ON "mshop_stock"',
Re: Syntax Error
Thank you for pointing out. Can you please create an issue in the https://github.com/aimeos/aimeos-core Github repository?
Re: Syntax Error
